The removal of the motherboard is a time consuming process. It involves the removal of most components from the phone. It also involves the use of a few tools such as a guitar pick, a heat gun, tweezers, a screwdriver, and plastic opening tools. You should be aware of the hazards and safety procedures of all tools before starting the process.
Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Use your fingers to remove the SIM card
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Use a heat gun at an approximate distance of 2-3 inches from the phone to apply heat to the phone and loosen up the adhesive in the display.
Starting from the upper left corner, insert a guitar pick in between the display and the phone case.
Use the pick to pry the display by sliding the pick in the direction shown.
Use the pick to pry the sides and lower part of the display by sliding the pick through the phone.
Using the guitar pick, lift the screen slightly.
Slightly lift, but do not remove, the upper end of display assembly.
Use the sharp tip of a guitar pick to lift the front panel assembly cable connector straight up off its socket on the motherboard.
Safely remove the front panel assembly from phone.
Use a Phillips 0 screwdriver to remove all 12 Phillips #0 screws.
Push upward from the back side your phone (where the battery should go) to pop out the large gray piece.
You should now have two different pieces. To continue we will only use the piece with the motherboard (Shown on the right side of the picture).
Use your finger or a plastic opening tool to disconnect the rear-facing camera from the motherboard.
Use your hands to gently remove the rear-facing camera from the motherboard.
Use your finger or a plastic opening tool to disconnect the proximity/light sensor from the motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to gently pull the proximity/light sensor out.
Use your finger or a plastic opening tool to disconnect the 3 button ribbon cable from the motherboard.
Use a plastic opening tool to disconnect the the blue wire shown in the picture.
After disconnecting the motherboard should come out easily.
Motherboard should look as shown in the picture.
crwdns2935229:019crwdne2935229:0
Display only the SIM port on board
