The PowerMac G4 M5183 is a model in the AGP Graphic Series. All AGP Graphic Series computers including models M6921, M7232, M7824, M7825, M7827 have similar issues with similar solutions.
Note: This troubleshooting guide covers the PowerMac G4 (AGP Graphic Series).
PowerMac G4 won't turn on
Your computer will not boot.
If your computer will not turn on, you see no lights, and hear no fans blowing, first check that it is plugged into a working power outlet. Also check that the red breaker on the back panel of your computer is set to the appropriate power setting. If your computer still fails to power up, your PMU battery may be dead, you may have a bad power supply, or your logic board may need replacing.
PMU battery is dead
The Power Management Unit (PMU), manages all power usages of your computer. When the PMU battery dies, the battery needs to be replaced and the PMU board needs to be reset. To replace the PMU, see our PMU repair guide.
Bad power supply
If the computer still does not start-up after replacing the PMU battery and resetting the PMU, then you may need to replace your computer's power supply.
Bad logic board
If replacing the power supply did not fix your PowerMac's booting problem, then you will need to replace the computer's logic board.
Display is not working
Your display is black.
Bad graphics card
First check that the monitor is functional. For example: you should see a power light on the display. You should hear a normal start-up sound when you power your computer on indicating that the computer is booting but not sending a video signal to the monitor. If the display is functional and the computer boots, but you see only a black screen, you will need to replace your graphics card.
Bad logic board
If replacing the graphics card did not fix your PowerMac's booting problem, then you will need to replace the computer's logic board.
Keyboard and/or mouse doesn't work
If you have access to another computer, try plugging the keyboard or mouse into that computer to see if the keyboard and mouse are functional. If they are not functional, then replace the mouse and keyboard. Otherwise, you will need to replace the logic board on your PowerMac.
CD-DVD ROM drive problems
Your disc is not being read.
Bad Disc
If the disc is not being read or is having trouble being read, the disc may be scratched. Check the bottom of the disc for any visible scratches.
Bad CD-DVD ROM drive
If your disc is not scratched and you are still having problems, you will need to replace the CD-DVD ROM drive. Such problems include failure to open, improperly reading discs, loud clicking, and/or whirring noises.
Audio problems
If your computer's audio is not working, first check that the speakers you are using are functional (i.e. plugged in and on). Test the speakers on a system that you know works. If the speakers are functional and the computer is simply not sending an audio signal, then you will need to replace your computer's logic board.
Flashing question mark on start-up
The computer displays the flashing question mark when it can't find a bootable operating system. This could be because your OS is corrupt, the computer doesn't have enough RAM, or your hard drive is failing.
Bad operating system
Try booting off an OS CD. Run Apple's Disk Utility and try to repair the disk. You could also try Alsoft's DiskWarrior. If this fails, reinstall your operating system. If you can, erase the hard drive prior to reinstalling the OS.
Not enough RAM
This is quite rare. If you have insufficient RAM for your computer to boot the operating system, you may get the flashing question mark. Installing more RAM or downgrading to an older operating system will fix this. You need 64MB RAM to run OS 9, 128 MB RAM to run OS X 10.0-10.4, and OS X 10.5 requires 512 MB RAM.
Bad hard drive
The hard drive may have been erased, corrupted, or damaged. If the hard drive has been erased, format it as HFS+ and reinstall your operating system back onto it. If it is corrupted or damaged, you need to replace it. Failing hard drives can display intermittent data corruption prior to failing completely. They often gradually get louder and start to click. If your hard drive is making abnormal clicking noises but still works, back up your data immediately and replace the hard drive.
Fan is noisy
If your computer's fan is noisy, first try cleaning it. If cleaning the fan doesn't reduce the noise to an acceptable level, then you should replace the fan.
USB, firewire, ethernet, and/or audio ports don't work
All of the ports on the back of your PowerMac (except for the display ports) are directly connected to the logic board. If any of these ports are not working, first check that there is no debris or contaminants in the port by cleaning them out. If the port continues to malfunction, then your computer's logic board needs replacing.
The computer loses track of time
If your computer looses track of time, then the PMU battery is dead and needs replacing. The power management unit (PMU), manages all power usage of your computer and keeps track of time when the computer is unplugged. When the PMU battery dies, the battery needs to be replaced and the PMU board needs to be reset.
Stephen Scruggs
crwdns2935283:001/20/10crwdne2935283:0
2,283 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-24, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 13-24, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S13G24
crwdns2935297:0156crwdne2935297:0
crwdns2944067:09crwdne2944067:0
I turned my power Mac G4 on for the first time in 5 years. The computer started just fine, the mouse and keyboard were working just fine. After a few minutes the mouse and keyboard stopped functioning, I tried different USB ports and a different mouse with no luck. I restarted the computer and although the computer turns on, the display won’t startup and the computer starts to sound like the fan is working extra hard. I’ve restarted the computer at least three times now with similar results: no display, no start-up, and fan whirling loudly. Diagnosis?
Austin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I
Well I'm a ten year old tech kid and my dad's g4 just stopped working. He hasn't used it for about a half a year and we just got a power outage about 2 weeks ago. I don't know if the power outage has anything to do with it but it was on sleep when that happend. I don't know if it needs a new PMU battery or what. maybe it just blew a fuse. I don't know. Tried unplugging and plugging back in. Tried holding down for 20 secs. It won't indicate power on the button board . He doesn't have a Apple studio display. Just a view sonic. Apple pro keyboard and Apple ball mouse. any ideas ?
Tristan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my problem is where it turns on, makes the startup chime, and tries to look for any startup files, but it doesn’t find any, the keyboard and mouse work, but it makes a VERY high pitched noise, any thoughts on what is causing that? i think its the psu, but i don’t have a working spare to test it, great forum btw.
Mikah Andony - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My problem is on a Power Mac G4 Model M5183 after I replaced the battery and pressed the PSU button. The computer started up normally and I reset the time and clock. Everything worked normally. I restarted the computer from the menu and it came back normally without any problems. However after shutting the computer down from the menu and press the ON button, the computer starts to boot up for 7sec and stops. Nothing appears on the screen. So, I open the computer side panel and pressed the PSU button and pressed the ON button and the computer boots up normally. Shutting down the system from the menu results in no boot up, again. The only way to get to the start up screen is to press the reset PSU button. Using the RESTART from the drop down menu is fine. I tried to use the First Aid on the HD and everything comes back OK. Any comments on how the fix my problem, other than pressing the reset PSU button each time before boot up would be appreciated. Thanks!!
GNOK
Wendell - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I run a Protools mix system on my G4 .As of lately it is booting up saying extensions are off and i can not open anything. Mouse moves but nothing will open up. what do i do ???
oneil gray - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 111
crwdns2959996:0crwdne2959996:0 36,205
