crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Black Pictures
Pictures develop as if unexposed and black.
The power from the battery is not connected to shutter
Check the battery compartment and check to see if the battery is properly connected to the battery case. The terminals of the battery should be properly attached to the ends of the battery case to complete the circuit. If necessary use a rubber band or tape to secure the battery in place.
Battery area is damaged
Often in a vintage camera an old battery has corroded, leaving residue on the battery and in the compartment. This should be cleaned off with a soft cloth or Q-tip dipped in white vinegar or Windex. If unable to clean, the battery can be replaced.
Insufficient Exposure
There should be two clicks when taking a photo and holding down the shutter button. This problem could be because you are not holding down the shutter for long enough, so the electric eye is not sensing enough light for the proper exposure. To fix this make sure the camera is on the appropriate indoor or outdoor setting using the lever under the lens.
Incorrect Film Speed
Film speed should be set to 75 for color and 3000 for black and white. If the film speed is set incorrectly, this could lead to photos that develop completely white or black.
Photo has Undeveloped Patches
A patch at the top or side of a photo is caused by uneven spreading of the film development chemicals within the image. This is a result of uneven spread roll pressure on the developing picture, and may signify that the spread rolls should be replaced.
Pictures have inconsistent light exposure
Picture looks cloudy or has dark or white edges
Wrong exposure setting
Change the indoor and outdoor setting to the appropriate environment to adjust the exposure.
Holes in Bellows
Wear on the bellows of the camera in the creases and folds could indicate leaky bellows. In this case, holes in the bellows would allow unwanted light to come in contact with the photo. This can be checked by shining a flashlight inside the bellows in a dark room and looking for light escaping through holes. This can be fixed by applying liquid electrical tape or rubber cement to the holes. If the bellow displays extreme wear and tear, the bellows may need to be replaced.
Black edges around the developed picture
Saggy bellows from old bellows can intrude onto the view of the image. The bellows must be replaced in this situation.
Stuck Bellows
If the bellows tend to get stuck while opening or closing, this could be a result of a faulty frame spring. Sometimes the spring can get damaged from overuse, and it may need to be replaced.
Shutter button does not click
The shutter button does not mechanically click twice successively.
No power connection
This could be caused by a faulty battery. In this case, the battery needs to be replaced. Make sure the battery terminals are securely attached to the battery compartments and clean if corroded.
Sticky Button
The shutter button may need to be cleaned carefully. If the problem persists, disassembly may be necessary. Upon disassembly, if you discover that the spring is broken it may need to be replaced.
Unclear Viewfinder
If the viewfinder is difficult to see through when taking a photo, it may have excessive dirt or it may be scratched. In order to solve this, the viewfinder lens must be cleaned or replaced.
Katie Miller
crwdns2935283:004/14/15crwdne2935283:0
680 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-3, Maness Spring 2015 crwdns2935289:0Cal Poly, Team 4-3, Maness Spring 2015crwdne2935289:0
CPSU-MANESS-S15S4G3
crwdns2936753:030crwdne2936753:0 41
crwdns2959996:0crwdne2959996:0 1,864
