Polaroid Automatic 100 Bellows Replacement
crwdns2869540:0crwdne2869540:0: 2976
4
31
95
2.976
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 3
crwdns2959982:03crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 20 - 30 crwdns2931279:0crwdne2931279:0
The bellows are the part of the camera that may be made of a material that is shiny and looks like the fluid part of an accordion.
    1. Polaroid Automatic 100 Bellows Replacement, Bellows: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid Automatic 100 Bellows Replacement, Bellows: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid Automatic 100 Bellows Replacement, Bellows: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Fully extend the bellows by lifting the #1 lever.
      • Remove the camera cover in order to make the camera easier to work with.
      • When collapsing bellows, press down on the metal frame above the bellows.
    2. Polaroid Automatic 100 Bellows Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Peel the two battery cable tabs off of the bellows.
    3. Polaroid Automatic 100 Bellows Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      • Remove one 15.5 mm flat head screw, with a 2.5 flathead screwdriver.
      • Remove two 2 mm flat head screws, with a 2.5 flathead screwdriver. Then carefully remove the cable cover.
      • Use the focus bar to extend bellows even further to access screws easier with the screwdriver.
    4. Polaroid Automatic 100 Bellows Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Automatic 100 Bellows Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Open the back cover by pushing the lever on the bottom towards the left.
    5. Polaroid Automatic 100 Bellows Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 3 mm screws, which are attached to the lens of the camera, using a Phillips #0 screwdriver.
      • To make the screws easily accessible, close the bellows by pushing on the metal frame.
      • When reassembling, orient the camera so that screws are screwed in downward and stay in place.
    6. Polaroid Automatic 100 Bellows Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully use a classic wide metal spudger to bend the tabs of the bellows.
    7. Polaroid Automatic 100 Bellows Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Automatic 100 Bellows Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the bellow tabs back with long needle nose pliers.
      • Remove the bellows.
Katie Miller
crwdns2935283:004/14/15crwdne2935283:0
680 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-3, Maness Spring 2015 crwdns2935289:0Cal Poly, Team 4-3, Maness Spring 2015crwdne2935289:0
CPSU-MANESS-S15S4G3
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 95
crwdns2959996:0crwdne2959996:0 2,976
