Note: This troubleshooting guide covers all Playstation 3 consoles.
PS3 Does Not Turn On
Your PS3 will not boot.
Power Cable
Verify that the power cable is plugged in properly and not loose. Also, verify that your source of power (the outlet) functions correctly.
Yellow Light of Death
The indicator light on the PlayStation 3 starts green, switches to yellow, and then quickly switches to red, and blinks indefinitely.
The PlayStation 3 will display this error for two different reasons. To determine what is causing the error on your console, turn the console on, and listen closely for the fan. If the fan powers on briefly, and then switches off, you have an issue with the motherboard. If the fan does not power on at all, then you likely have an issue with the power supply.
Motherboard
The most common cause of the YLOD error and the PlayStation 3 failing to boot is a hardware malfunction on the motherboard. The error is caused by the failure of the solder joints between the CPU and GPU and the motherboard. This error can be fixed by re-soldering the chips to the motherboard, and, while not a 100% guaranteed fix, it is the best option for repairing the YLOD. iFixit offers both kits and guides to facilitate this fix.
Power Supply
One cause of the PlayStation 3 not booting is a faulty power supply. A much smaller percentage of PS3 consoles will display the yellow light as a result of a faulty power supply. If the power supply is faulty, then it will need to be replaced.
PS3 Doesn't Read Optical Media
There are two models of Blu-ray drives for the fat models of PlayStation 3, each with parts specific to their own model. The easiest way to tell which kind of drive is in your PlayStation 3 is to take the drive out and look at it. If the drive has an exposed control board on the bottom of the Blu-ray drive, the Blu-ray drive's model number is KEM-400. If there is no exposed control board, then the Blu-ray drive's model number is KEM-410.
If your PlayStation 3 is not reading discs, or is reading discs inconsistently, then follow this flow chart to fully diagnose the problems with your Blu-Ray Drive.
Step 1. Insert a disk into the PlayStation 3 Blu-ray Drive
- Q1. Does the PlayStation accept the disk?
- Yes - Go to "Step 2"
- No - Go to "Q2"
- Q2. Is the Blu-Ray Drive Blocked?-There is a physical barrier preventing your PS3 from drawing in disks
- Yes - Go to "SOLUTION: Gear Alignment Reset"
- No - Go to "Q3"
- Q3. Does the disk eventually get drawn into the console? - You push the disk in ~3/4 of the the way, and the mechanism draws the disk into the console
- Yes - Go to "SOLUTION: Broken sensor board."
- No - Go to "SOLUTION: Faulty Control Board"
Step 2. Clean the Disk - Using a cleaning solution and a microfiber cloth, clean the disc.
- Q4. Does the PlayStation read both Blu-ray disks and DVDs?
- Yes - Go to "SOLUTION: Your done!
- No, it reads one media type, but not the other - Go to "Step 5"
- No - Go to "Step 3"
Step 3. Eject the disk
- Q5. Did the disk come out in the same orientation that it was inserted?
- Yes - Go to "Step 5"
- No - Go to "Step 4"
Step 4. Re-insert the disk into the PlayStation 3
- Q6. Is the loading wheel present on the XMB?
Step 5. Clean the Lens
- Q7. Does the PlayStation read both Blu-ray disks and DVDs?
- Yes - Go to "SOLUTION: You're done!
- No, it reads one media type, but not the other - Go to "SOLUTION: Faulty Lens"
- No - Go to "Step 6"
Step 6. Eject the disk
- Q8. Did the disk come out in the same orientation that it was inserted?
- Yes - Go to "SOLUTION: Faulty Lens"
- No - Go to "Step 7"
Step 7. Re-insert the disk into the PlayStation 3
- Q9. Is the loading wheel present on the XMB?
Solution: Gear Alignment Reset
Realigning the gears in the blu-ray drive is fairly simple. Depending on the type of Blu-ray drive you have, you will need to either follow this guide or this guide.
Solution: Broken Sensor Board
Only the KEM-400 optical drives have IR sensors for discerning when discs are inserted into the Blu-ray drive. If your IR Sensor is no longer working, you can attempt to replace it, however, it will in no way affect the performance of your Blu-ray drive.
Solution: Faulty Control Board
If you have judged that the Control Board is no longer functioning properly, then you will likely need to send your PlayStation to Sony. The Control Board is paired to the Motherboard and will only work with its original partner board.
Solution: You're done!
If everything is working great, then you no longer need this troubleshooting guide. Congratulations!
Solution: Faulty Lens
Being a very fragile piece of technology, it is easy for the lens to break. Both types of Blu-ray drives have a specific lens that will only work with that type of drive. Depending on which type of drive you have, follow this guide (KEM-400) or this guide (KEM-410)d to replace the laser
PS3 Freezes
The PS3 continues to freeze or has excessive lag.
Restart the PS3
If your PS3 freezes, turn off the game system by holding down the power button. Turn it back on by pushing the power button again.
Internet Connection
If you have continuous, excessive lag during online play, you should first verify that the ethernet cable is properly plugged in. Also, try restarting your router and/or modem. If you continue to have lag, the problem may be your internet connection. Talk to your service provider for additional help.
Note: The PS3 is not meant to be used with dial-up connections; it is designed for broadband networks.
Hard Drive
If your PS3 lags or freezes when loading content from the hard drive, the drive either lacks free space or is faulty. To create more space, try removing items from your hard drive or getting a new hard drive with a higher storage capacity. A faulty hard drive must be replaced.
PS3 Sound/Video Problems
The PS3 has problems pertaining to sound and video.
Sound
For problems with sound:
- Verify that the TV or audio system is not muted.
- Check the settings of your audio output device to make sure it "sees" the PS3. Also, verify that you are using the correct audio cables and that they are properly connected.
- When playing audio discs, verify that the music you are trying to play is not copy-protected. Certain copy-protected discs may not play.
- Verify that your system's audio input and output settings are set up correctly.
Video
For problems with video:
- Verify that the input mode on your TV is compatible with the connectors used by the PS3.
- Your PS3 video settings may have compatibility issues with your video output. To reset the PS3 to standard video, disconnect all components, power down the system, and hold down the power button until you hear two beeps, then let go.
- Ensure that the video definition is the same for both the TV and the PS3. When using a HDTV, the PS3 must be properly set up or the image will be distorted.
crwdns2944067:0237crwdne2944067:0
Interesting helpful Information. For more related discussions visit the PS3 Community - http://community.us.playstation.com/comm...
gerry smith - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
help me when i turn on my ps3 it stay with a green light but my screen says no signal so when i tried to turn off my ps3 it wont it stays on and i cant even do anything
iamthekiller91 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i have the same problem didu find the problem?
nikosgena - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I'm having that same problem
Darrick Williams - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
For those of you having the video issue most likely its an hdmi error what happens is somehow you got the setting set fir the av cables which is the same one the ps2 uses its for standard def but nothing will come on with hdmi hooked. Start your ps3 by hitting the power button but keep it held down it will beep turn off and restart you can let go as soon as its restartng this is a manual hard reset of all the settings reverting them to default it will not mess up any of your content profiles or anything like that the screen will pop up and tell you it detects hdmi if thats what ur using it will give a 30 second preview select yes to keep the settings problem fixed
Leo Pothier - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
