Yellow Light of Death Repair
crwdns2869540:0crwdne2869540:0: 1.7M
86
558
2,698
1,695,870
crwdns2955950:0crwdne2955950:0: 372
crwdns2960004:0142crwdne2960004:0, crwdns2960008:0230crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 1275
crwdns2959974:01275crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 732
crwdns2959982:0732crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
crwdns2862627:0crwdne2862627:0
crwdns2862628:0crwdne2862628:0
Use this guide to potentially repair PlayStation 3s with the "Yellow Light of Death" error.
This procedure may not completely revive your console. Since the “Yellow Light of Death” is a generic hardware error, the issue can range from an overheating CELL/RSX from dried thermal paste underneath the IHS, bad NEC/TOKIN capacitors, a short on the board, faulty RSX, etc. This guide may only temporarily fix consoles with a faulty flip chip (most likely RSX but CELL could also be at fault). An RSX/CELL replacement (requiring a BGA rework station) would be required to permanently repair a console with a faulty flip chip.
Note: Your PlayStation may look slightly different inside. Be cautious when performing this process on your machine.
crwdns2959948:0crwdne2959948:0
crwdns2959952:0crwdne2959952:0
crwdns2936621:0crwdne2936621:0
    1. Yellow Light of Death Repair, Smart Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair, Smart Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
      • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
    2. Yellow Light of Death Repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
    3. Yellow Light of Death Repair: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
    4. Yellow Light of Death Repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
    1. Yellow Light of Death Repair, Top Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following seven screws:
      • Six 52 mm Phillips screws
      • One 30 mm Phillips screw
    2. Yellow Light of Death Repair: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
      • Remove the top cover.
      • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
    1. Yellow Light of Death Repair, Blu-ray Disc Drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the Blu-ray power cable from the motherboard.
      • Pull the connector straight up and out of its socket.
    2. Yellow Light of Death Repair: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
    3. Yellow Light of Death Repair: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Pull the ribbon cable out of its socket.
      • Remove the Blu-ray drive from the PS3.
      • If replacing the Blu-ray drive, transfer the power cable to your new drive.
    1. Yellow Light of Death Repair, Motherboard Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
    2. Yellow Light of Death Repair: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 12 mm Phillips screws securing the control board to the lower case.
      • Remove the control board and its attached cable from the PS3.
    3. Yellow Light of Death Repair: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following eight screws securing the motherboard assembly to the lower case:
      • Seven 12 mm Phillips screws (ph2)
    4. Yellow Light of Death Repair: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the control board bracket.
    5. Yellow Light of Death Repair: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
      • Remove the hard drive bay cover.
    6. Yellow Light of Death Repair: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the motherboard assembly out of the lower case.
    1. Yellow Light of Death Repair, AC Inlet: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 7.7 mm Phillips screw securing the ground strap to the chassis.
    2. Yellow Light of Death Repair: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
      • While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
    3. Yellow Light of Death Repair: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the AC inlet out from the bottom of the rear cover, minding any of its cables that may get caught.
    1. Yellow Light of Death Repair, Rear Cover: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair, Rear Cover: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • While lightly pulling the rear cover away from the logic board assembly, use the flat end of a spudger to release the clips along the top and bottom edges of the rear cover.
    2. Yellow Light of Death Repair: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the rear cover from the logic board assembly.
    1. Yellow Light of Death Repair, Heat Sink: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair, Heat Sink: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • De-route the fan cables from the plastic finger molded into the heat sink.
      • Disconnect the fan from the motherboard.
    2. Yellow Light of Death Repair: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
    3. Yellow Light of Death Repair: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the memory card reader out of the PS3 enough to access its ribbon cable.
      • Flip up the retaining flap on the memory card reader ribbon cable socket.
      • Pull the ribbon cable out of its socket and remove the memory card reader.
    4. Yellow Light of Death Repair: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the DC-In cables from the front of the heat sink.
      • Pull the connector toward the front of the PS3.
    5. Yellow Light of Death Repair: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five 9 mm Phillips screws securing the power supply to the chassis.
    6. Yellow Light of Death Repair: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the power supply by its front edge to clear the two posts attached to the motherboard.
      • Remove the power supply.
    7. Yellow Light of Death Repair: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 16.5 mm shouldered Phillips screws securing the heat sink to the motherboard.
      • Remove the two brackets held under the screws you just removed.
    8. Yellow Light of Death Repair: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the motherboard assembly off the heat sink.
      • The heat sink may still be held in place by the thermal paste. If this is the case, gently pry the heat sink away from the motherboard housing. Make sure to not bend the copper piping on the heat sink.
      • Be sure to apply a new layer of thermal paste when reattaching the heat sink.
      • Never applied thermal paste before? Our thermal paste guide makes it easy.
      • If you're following the YLOD repair guide, stay tuned for where to apply the replacement thermal paste.
    1. Yellow Light of Death Repair, Motherboard: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair, Motherboard: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip up the retaining flap on the Blu-ray ribbon cable socket.
      • Remove the Blu-ray ribbon cable.
    2. Yellow Light of Death Repair: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip up the flap on the memory card reader ribbon cable socket and remove the ribbon cable.
    3. Yellow Light of Death Repair: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip up the retaining flap on the Wi-Fi/Bluetooth ribbon cable socket.
      • Pull the Wi-Fi/Bluetooth ribbon cable out of its socket.
    4. Yellow Light of Death Repair: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the DC-In cable from the motherboard and set it aside.
      • Pull the connector straight up and out of its socket on the motherboard.
    5. Yellow Light of Death Repair: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the PRAM battery from the motherboard.
      • The PRAM socket is delicate and has the potential to break off the motherboard. If possible, hold down the socket as you disconnect the PRAM battery cable.
    6. Yellow Light of Death Repair: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Rotate the PRAM battery slightly counter-clockwise and remove it from the motherboard assembly.
    7. Yellow Light of Death Repair: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the blue 8 mm Phillips screw securing the hard drive cage to the chassis.
    8. Yellow Light of Death Repair: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push the hard drive cage toward the front of the motherboard assembly.
      • Remove the hard drive from the motherboard assembly.
    9. Yellow Light of Death Repair: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 3.7 mm #0 Phillips screws securing the chassis to the hard drive socket.
    10. Yellow Light of Death Repair: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 8.3 mm #0 Phillips screws securing the two halves of the motherboard together.
    11. Yellow Light of Death Repair: crwdns2935265:039crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully feed the Wi-Fi/Bluetooth ribbon cable through the hole in the top motherboard cover.
      • Remove the top motherboard cover.
    12. Yellow Light of Death Repair: crwdns2935265:040crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the motherboard from the bottom motherboard cover.
    13. Yellow Light of Death Repair: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the Wi-Fi/Bluetooth ribbon cable from the motherboard.
      • Motherboard remains.
    1. Yellow Light of Death Repair, Yellow Light of Death (YLOD) Fix Kit: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair, Yellow Light of Death (YLOD) Fix Kit: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Arctic Silver ArctiClean
      $11.99
      • Using the flat end of the spudger, remove the old thermal paste off the CPU and GPU on the motherboard.
      • Using a cleaner such as Arctic Silver's ArctiClean or high alcohol content rubbing alcohol, clean the CPU and GPU.
      • Clean the thermal paste off of the heat sink in the same way.
    2. Yellow Light of Death Repair: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using your fingers or the flat end of a spudger, remove the old thermal pads on the logic board as indicated:
      • Large square thermal pads
      • Small square thermal pads
      • Small rectangular thermal pads (located on the underside of the board, as highlighted in the second picture)
      • Some of the smaller thermal pads may be attached to the metal casing that surrounds the motherboard rather than the motherboard itself.
    3. Yellow Light of Death Repair: crwdns2935265:044crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Set the heat gun to "Low" or around 300C (575F), and let it run for a few seconds to reach operating temperature.
      • Holding the motherboard upright, warm up the entire board with the heat gun. The board should be warm, but not too hot.
      • This will prevent damage to the board caused by localized thermal expansion.
    4. Yellow Light of Death Repair: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Set the motherboard on a support so that the CPU and GPU are completely supported and level.
      • The support should be something that can resist temperatures upwards of 300 degrees Celsius. Suggestions: scrap lumber, old books, cardboard box.
      • In the next few steps, you will be reflowing the solder under the chips marked in red.
      • Once you begin reflowing the chips, do not touch or move the motherboard until it is completely cool. Doing so can render the motherboard irreparably damaged.
    5. Yellow Light of Death Repair: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a circular motion, evenly heat (using low heat) the two processors labeled "RSX" and "CELL" for 2 minutes while keeping the gun about 1/2" above the chip. For the Lower two areas heat for 30 seconds following the same distance guidelines from above.
      • Begin heating the GPU, marked "RSX", and heat the chips in a zig-zag order.
    6. Yellow Light of Death Repair: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Continue heating the chips using the same circular motion as described above, for about 25 seconds each.
    7. Yellow Light of Death Repair: crwdns2935265:048crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:048crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:048crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Ensure that the motherboard has completely cooled before continuing this guide.
      • If you have not applied thermal paste before you can check our thermal paste guide whilst it is cooling.
      • Apply a thin bead of thermal paste on the CPU.
      • Using the thermal paste spreader card, spread the paste out thinly and evenly on the chip.
      • In the same way, apply a thin layer of thermal paste on the GPU.
      • Clean up any excess thermal paste off the motherboard.
    8. Yellow Light of Death Repair: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yellow Light of Death Repair: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Apply the fresh thermal pads to the motherboard in the locations indicated:
      • Large square pads
      • Small square pads
      • Small Rectangular Pads
      • If you'd like to cut your own thermal pads, you'll need material about 2-2.5mm in thickness. Thanks to user howardsarah34 for the exact measurements for the thermal pads.
      • Two 3cm x 3cm Squares
      • Ten 1cm x 1cm Squares
      • Five 1.5cm x 0.5cm rectangles
    9. Yellow Light of Death Repair: crwdns2935265:050crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Peel the remaining white plastic cover off the other side of thermal pads.
To reassemble your device, follow these instructions in reverse order starting at step 41.
crwdns2935229:01275crwdne2935229:0
Brett Hartt
crwdns2935283:004/12/10crwdne2935283:0
132,621 crwdns2915208:0crwdne2915208:0
crwdns2935297:0144crwdne2935297:0
Staff
crwdns2935297:072,955crwdne2935297:0
crwdns2947412:0230crwdne2947412:0
Done this twice, first time it lasted 2 weeks and the second time 10 days. I'll do it one more time and if it goes again, I think I'll be buying a new console.
Great repair guide, clear and simple -I don't know why it's rated as difficult -there's no soldering or wiring to do.
Franco - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Watch rip Felix's video on it ( it's long) but he goes into all detail on what to do and not to do. Short answer, the ylod is bound to happen at some point no matter what, and it can be caused by basically anything. Watch the video and he explains it well.
Purple boi - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Great kit! And it worked! We have brought the PS3 back to life! Hoping it stays this way! But for the price of the kit it is worth the try!
ekozocas - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I completed this repair last night. It wasn't as hard as I thought, though it did take me almost 3 hours to accomplish. My PS3 is back up and running, and the fan is so guiet not I can hardly hear it.
I will add that these pictures provided are from a 60GB launch PS3. I have an 80GB (MGS4 Bundle), and some of the inner workings are a little different. The card reader remains attached to the upper casing, and the ground wire for the A/C switch is run under the power supply... as opposed to over it as it is in this guide.
Overall, this is a great guide and the kit was a great price. I hope my PS3 will remain operational at least through Christmas... I've got my eye on the UC3 Bundle; )
jshaas - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 86
crwdns2936753:07crwdne2936753:0 558
crwdns2936753:030crwdne2936753:0 2,698
crwdns2959996:0crwdne2959996:0 1,695,870
