Note: This troubleshooting guide only covers the Palm Treo 650. Other Palm Treo phones may be covered in other guides.
WARNING: By trying to repair the Palm Treo 650 yourself, you may nullify your warranty. Check with your provider before making any repairs yourself.
Palm Treo 650 won't turn on
These are some basic reasons why your phone will not turn on.
Battery issues
Your battery could be completely drained. If you have tried charging the Palm Treo 650 and it still will not turn on, then you may need to replace your battery. Follow the guide to take out your battery.
Keypad issues
If you have owned your Palm Treo 650 for a long time, it is possible that the keypad has been worn down because of extensive use. If you believe that this could be the reason why your phone will not turn on, follow the guide to repairing your keyboard.
Screen issues
There is a possibility that your screen is no longer functioning. If all the lights on your phone are lit up but there is still no picture on the screen, then you could have cracked or broken your screen somehow. To fix this problem, follow the guide to removing your screen.
Problems during a phone call
The sound is fuzzy, there is no sound at all, or you can hear them but they can't hear you.
Reception issues
First, you will want to check your reception to make sure it is not just occurring because of bad reception. If you have good reception and the sound issues persist, you may want to look at some of the issues below.
Earphone issues
If either the sound is fuzzy or there is no sound at all, then you could be having a earphone issue. This problem should occur constantly and not just once. If you believe that this is your problem, follow the guide to removing your earphone.
Speaker issues
If you are trying to put your phone on speaker phone and the sound is fuzzy or there is no sound, then you could be having speaker issues. This problem should occur constantly and not just once. If you believe that this is your problem, follow the guide to removing your speaker.
Microphone issues
If you are trying to talk with someone and you can hear them but they can't hear you, then you may be having microphone issues. This problem should occur constantly and not just once. If you believe that this is your problem, follow the guide to removing your microphone.
nhara
crwdns2935283:011/15/09crwdne2935283:0
46 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team 19-3, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 19-3, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S19G3
crwdns2935297:0108crwdne2935297:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 3,218
