Palm Treo 650 Earphone Replacement
    1. Palm Treo 650 Earphone Replacement, Battery and Stylus: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Position the phone so the screen faces down.
      • Remove the stylus found on the back of the phone.
    2. Palm Treo 650 Earphone Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hold the button in the middle of the phone's back to remove the battery cover.
      • Slide the cover down to remove it, and set the cover aside.
    3. Palm Treo 650 Earphone Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 650 Earphone Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the edge of the battery, separating contact points, and pull out as pictured.
    1. Palm Treo 650 Earphone Replacement, Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the round, rubber cover to expose a screw that will be removed in the next step.
    2. Palm Treo 650 Earphone Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 650 Earphone Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
      • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
    3. Palm Treo 650 Earphone Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the antenna outward to remove the antenna from the body of the phone.
    4. Palm Treo 650 Earphone Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 650 Earphone Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry the back cover off using an iFixit opening tool.
      • Several small clips on the inside attach to the back cover.
    1. Palm Treo 650 Earphone Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Palm Treo 650 Earphone Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Palm Treo 650 Earphone Replacement, Motherboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the ribbon cable before removing the motherboard.
      • Unclip the gray tab.
      • Pull out the orange ribbon cable.
    2. Palm Treo 650 Earphone Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 650 Earphone Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull off the motherboard.
    1. Palm Treo 650 Earphone Replacement, Earphone: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Palm Treo 650 Earphone Replacement, Earphone: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Palm Treo 650 Earphone Replacement, Earphone: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull out the earphone by grabbing the black rubber piece identified in the picture.
cgood
crwdns2935283:010/28/09crwdne2935283:0
134 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-3, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 19-3, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S19G3
crwdns2935297:0108crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 81
crwdns2942667:0crwdne2942667:0 3,497
