crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Gimbal Function Is Unresponsive
Device will not pitch, roll, yaw, or pivot.
Gimbal Joystick Not Responding To User Input
Test bluetooth connection to device. If connected and the joystick does not produce any movement, the joystick will need to be replaced.
Gimbal Does Not Move Correctly
If the gimbal function does not work at all, check the Bluetooth connection. If connected, the electronic aspect of the gimbal may need to be replaced. If the gimbal works but does not move as quickly as it should, thoroughly clean the device and make sure no obstructions are impeding motion.
Buttons Are Unresponsive
You are unable to receive a response from buttons.
Stuck/Broken Trigger Button
If the trigger button is stuck or broken and does not produce any output from the device, the part may need to be replaced or simply repaired.
Stuck/Broken Push Button
If no response is observed when a button is pressed, the button may need to be repaired or replaced. (link)
Unit Is Not Turning On
You are unable to charge or turn on device.
Dead Battery
Ensure the battery is dead by testing it using a voltmeter if available, or by checking to see if the device only works when plugged into a charging port. If the battery is dead as confirmed by the above processes, the battery needs to be replaced.
Corroded/Bent/Loose Battery Connectors
If the battery is tested and functions correctly, the issue could be with the battery connectors, and they will need to be replaced.
Unresponsive Sensor
The sensor that allows your phone to be detected is not working.
Undetected Black Phone/Case
If the phone being used is not detected by the sensor, it could be due to a known issue with the device detecting black phones. Use a white piece of paper to cover the sensor when in use, or switch to a lighter phone case.
Damaged Sensor
Ensure the sensor itself does not function by using different phones to attempt to use the device. If the device does not sense any device, the sensor must be replaced. (link)
Device Is Unable To Connect
Your phone won’t connect via Bluetooth or Wi-Fi
Bluetooth Undiscoverable
If bluetooth will not connect to phone, consider updating the DJI GO app to the latest software. If the problem continues, replace bluetooth module.
Activation Error
Make sure the phone is connected with Wi-Fi to assure a successful first time activation. If the Wi-Fi isn’t working, try resetting your router, or replacing the Wi-Fi module.
Phone Mount Unable To Hold Phone
The phone mount is unable to hold the phone, or is loose and affects device performance.
Defective Tightening Apparatus
If the clamps are unable to properly hold the phone, check the tightening knob. If the knob does not move or is stuck, remove or replace it. If the knob moves but does not tighten the clamp, ensure the clamps are not obstructed. If the clamps are not obstructed, the knob may be broken and can be repaired or replaced.
Broken Clamps
If the clamps themselves are broken in some way, remove and replace the clamps that are broken.
William Tyler Wills
crwdns2935283:009/28/17crwdne2935283:0
432 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G1, Nance Fall 2017 crwdns2935289:0USF Tampa, Team S2-G1, Nance Fall 2017crwdne2935289:0
USFT-NANCE-F17S2G1
crwdns2944067:032crwdne2944067:0
Your device could be paired with another nearby phone. Temporarily disable Bluetooth on any nearby phones that your Osmo Mobile may be paired with. This releases the Osmo Mobile to pair with another phone.
anonymous 7859 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I keep getting a message that says device error ,turn off and reposition device while I'm recording, what causes this?
John Mendoza - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My gimbal doesn’t move after balance setting and Bluetooth connected. Joystick buttons are not responsive
akthomas1981 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Osmo Mobile 1 wont balance my iphone 7 plus when off even though I made full adjustment to the balancing adjustment. But before it will be able to balance my iphone 7 plus.
What could be the problem?
alanuychan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi when i try after setting my osmo 3 up with phone all functions work apart from camera starts and stops after 2 seconds. I can control the osmo 3 up down so on but camera turns off
richfruit17 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 54
crwdns2936753:030crwdne2936753:0 207
crwdns2942667:0crwdne2942667:0 51,791
