Osmo Mobile Bluetooth Module Replacement
    1. Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove gimbal from base handle by loosening round plate found at the top of the handle.
    2. Osmo Mobile Bluetooth Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
      • Carefully detach handle from gimbal and disconnect the cable that connects the two.
    3. Osmo Mobile Bluetooth Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
    4. Osmo Mobile Bluetooth Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove joystick by gently pulling away from handle
    5. Osmo Mobile Bluetooth Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
      • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
    6. Osmo Mobile Bluetooth Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate four screws directly on top of handle.
      • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
      • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
      • Remove the remaining two screws found on the front of the faceplate.
      • Remove the rest of the face plate shell.
    1. Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate and remove the black screw found at the base of the grey mounting plate.
      • Remove the grey face plate.
    2. Osmo Mobile Bluetooth Module Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Open the battery hatch and remove it by using the tweezers to press the hinge into the device.
      • Remove the black screw located underneath where the battery hatch was.
    3. Osmo Mobile Bluetooth Module Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the spudger to remove the front handle casing by sliding the spudger into the area between the handle grooves.
      • Slide the spudger around the groove to find the 6 clasps that hold the front part of the handle, and unclasp them.
      • Take off the front handle section to reveal the whole interior of the device.
    4. Osmo Mobile Bluetooth Module Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Osmo Mobile Bluetooth Module Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate and remove the black screw in the center of the motherboard chip.
      • Remove motherboard and replace.
William Tyler Wills
crwdns2935283:009/28/17crwdne2935283:0
432 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G1, Nance Fall 2017 crwdns2935289:0USF Tampa, Team S2-G1, Nance Fall 2017crwdne2935289:0
USFT-NANCE-F17S2G1
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 2,355
