crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
OnePlus One Will Not Charge
The OnePlus One does not charge as a result of being plugged in or does not recognize the presence of a charging cable.
Bad Charging Cable Connection
If your phone's battery won't charge, it could be the result of a bad charging cable. If you have been trying to charge your phone by plugging it into a computer or tablet, it may not be receiving enough power. For best charging results, plug into a wall outlet instead of a computer or tablet. If the phone still will not charge, check the cable for any damage. If you detect damage to the cable, try using a different charging cable. If your cable is damaged and using a different cable works, you will have to find a permanent replacement for your damaged cable.
Obstructed/Bad Micro USB Port
If your OnePlus One still isn’t charging, it’s possible that your device’s Micro USB Port is faulty and is preventing your device from charging. Check for Debris in the Micro USB port of your OnePlus One device. Clean out any debris in the Micro USB port by using a brush, toothpick, or compressed air. If this doesn’t resolve your issue, your device may have a defective Micro USB port. You can either contact OnePlus Customer Service or attempt to replace it yourself using the OnePlus One Micro USB Port Replacement guide.
Defective Battery
If your device still isn’t charging, the issue could lie within the battery. While some cellphone models have easily removable batteries, the battery in the OnePlus One is manufactured into the device to dissuade removal. This makes it difficult to replace defective batteries. To replace the defective battery yourself, use the OnePlus One Battery Replacement guide.
OnePlus One Will Not Turn On
OnePlus One remains unresponsive, even when the power button is pressed.
Drained/Dead Battery
If your phone id not turning on even when plugged in, the battery could be completely drained. Plug your OnePlus One into a wall outlet via the charging cable and wall adapter and let it fully charge before attempting to turn it on. If phone is not charging, check the OnePlus One will not charge section at the top of the page.
Bad Display
If the phone sounds like it’s working or behaving as normal but the screen is black, your device’s screen may be defective. To test if the screen is still functioning, perform a hard rest on the phone by doing the following:
  1. Press and hold down the Power button.
  2. Immediately after holding down the power button, press and hold down the Volume Down button.
  3. While still holding down the Power and Volume Down buttons, wait until you see the screen light up.
  4. After you see the screen light up, release both buttons.
  5. Select the option at the top of the screen that reboots your phone.
If during the hard reset process, your screen never lights up, then your screen is no longer functioning properly and most likely needs to be replaced. You can replace the defective screen yourself using the OnePlus One Display Assembly Replacement guide.
Rear Camera Not Functioning
Unable to take photos using the rear camera.
Rear Camera Not Selected
If your phone isn't taking photos via the rear-facing camera, your phone may not have the rear-facing camera selected. Check your phone's camera settings to ensure your device has the rear-facing camera selected and ready to take photos.
No Available Memory
If the rear-facing camera is selected but your phone still won't take photos, your phone's internal memory could be full. Ensure your device has enough storage space available to take photos by checking your phone's available memory in the 'Storage' settings.
Faulty Rear Camera
If your rear camera has been selected and your memory is not full but the phone still won’t take photos, your camera may need to be replaced. You can replace the faulty rear camera yourself using the OnePlus One Rear Facing Camera Replacement guide.
Front Camera Not Functioning
Unable to take photos using the front camera.
Front Camera Not Selected
If your phone isn't taking photos via the front-facing camera, your phone may not have the front-facing camera selected. Check your phone's camera settings to ensure your device has the front-facing camera selected and ready to take photos.
No Available Memory
If the front-facing camera is selected but your phone still won't take photos, your phone's internal memory could be full. Ensure your device has enough storage space available to take photos by checking your phone's available memory in the 'Storage' settings.
Bad Front Camera
If your front camera has been selected and your memory is not full but the phone still won’t take photos, your camera may need to be replaced. You can replace the bad front camera yourself using the OnePlus One Front Facing Camera Replacement guide.
GPS Not Working
The device’s GPS cannot accurately identify the device’s location.
GPS Not Enabled for the App You’re Using
On the OnePlus One, all apps use the Google framework to access your location. If a certain app is not finding your location, it may mean that Google doesn’t have access to the app. Ensure that you have allowed Google apps to have access to your location in the non-functioning app. You can check to make sure that apps have permission to GPS data in your device’s settings.
GPS Accuracy Isn’t Good Enough
If your phone can’t stay locked on to your current position, you may need to improve the GPS accuracy. In your device’s GPS settings, change location to ‘High Accuracy’.
GPS Cache May Be Corrupted
If the previous setting changes haven't improved your GPS, you may need to clear the GPS cache, which is different than clearing the Android cache. To clear the GPS cache, download the GPS Test app on your phone. If the GPS Test app doesn’t show any improvement on your phone, you can also try a GPS improvement app, such as GPS Status or Faster GPS.
Stuck in Airplane Mode
Device gives “Turn Airplane Mode Off” error message despite Airplane Mode never having been activated.
Ensuring Your Operating System is up to Date
Many of the “work-around” hacks, provided in forums regarding this subject, are obsolete with the OnePlus One’s newest operating system. The problem itself has also widely been resolved with the introduction of the newest operating system, though it continues to persist in much smaller numbers. Check your phone’s setting to see if there’s a software update available. If your device is unable to update to the newest operating system because of the error, you will need to perform a Soft Reset or a Hard Reset to resolve your issue. Please back up any important info on your phone (photos, videos, music, etc.) before doing a reset.
Soft Reset
Follow the below instructions to perform a Soft Reset:
  1. If your display is off, turn it back on using the power key
  2. Open the ‘Settings’ application
  3. Scroll down until you find ‘Backup & Reset’
  4. Tap on ‘Factory Data Reset’
  5. Select ‘Reset Phone’
  6. Tap on the box ‘Erase Everything’
  7. The device should automatically reboot
Hard Reset
Follow the below instructions to perform a Hard Reset:
  1. Turn your phone off by pressing down the power key for five seconds
  2. Turn the phone back on while keeping the ‘Volume Down’ button pressed in
  3. When the phone vibrates, release the ‘Volume Down’ button
  4. Your phone should enter a mode called ‘Simple Recovery’
  5. Choose the option that reads ‘Wipe Cache Partition’ using the power button
  6. You should get a message that says ‘Cache Wipe Complete’
  7. Continue to choose the option ‘Wipe Data/Factory Reset’
  8. The phone should automatically reboot
Chad Jackson
crwdns2935283:009/22/14crwdne2935283:0
5,370 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-3, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 3-3, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S3G3
crwdns2944067:010crwdne2944067:0
Feb 27th 2016
How to fix a problem that when trying to make a phone call it says "Turn Flight Mode to off".
Sure I move it to non flight mode, but no reception of network mobile cells.
alternative, where to buy a main board or the RF section?
Was bought in 2014, no warranty any more. It was never touched or opened or fixed before.
Thank you.
dudi - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
A few months back, awoke to what appeared to be a "dead battery" on my OPO.
Everything I tried failed to awake it. The phone had been fully charged that evening and removed from charger. My conclusion, dead battery and a $100 repair bill in my future.
A few days later, I decided to try one last time to reawaken it. After 10 minutes of pushing/holding various buttons, I held down both DOWN VOLUME and POWER/LOCK-KEY buttons for 60-90 seconds. BOOM! All of a sudden screen lit up displaying rough diagram of a battery & statement something like 'insufficient battery power to awake phone, connect charger". I immediately connected charger, and about 30 minutes later checked and saw battery being recharged, and was now at 30% of capacity.
Since that time, my OPO has worked flawlessly. No repeat of "dead battery" problem.
(NOTE: My OPO is currently running CM12.1.1-YOG7DAS2K1 [Android L v5.1.1] and has never been modified, except as may have been initiated in official OTA updates released by CyanogenMod.)
Wald Wolf - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
how about keep rebooting and not going to primary menu..,. the phone always rebooting on oneplus logo?
Art Play - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The switched off just i plug in the charger.
And it doesn't start with the power button.
Neither it allows to go for hard reset
And it only restarts when i plug in the charger again.
Mayur Jadav - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
OnePlus 7t pro not charging while turned off. It goes in a loop to show OnePlus logo and off if i connect charger before turning off the phone and then switches off. It won't charge. Tries hard reset , software manual update. Now i am worried if my phone charge completely drain and never charge
JITHIN JAZz - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 84
crwdns2959996:0crwdne2959996:0 89,349
