Note: This troubleshooting guide covers problems with the Olympus Stylus 760 digital camera.
LCD screen is blank
The LCD may be damaged
  • If the LCD screen is cracked, it will need to be replaced
  • The screen may be damaged internally, and should be replaced
The LCD may have become disconnected
Camera won't turn on
Battery is dead/drained
  • If the camera has not been in use for a while, the battery power may be completely drained. Recharge the battery and then try to turn on the camera.
* The battery may have reached the end of its life and is no longer capable of holding a charge. You will need to purchase a replacement battery. See Replacing the Olympus Stylus 760 battery.
Battery is not inserted properly
Memory card won't fit into camera
Memory card is not proper size for camera
  • The memory card is not the right size for the camera. Make sure the memory card that you have inserted is an xD-Picture Card size 16MB-2GB .
Memory card is not inserted into the camera properly
  • The memory card may have been improperly inserted. Make sure the memory card goes in easily, do not force the memory card into the camera. Check for debris in the memory card slot and clean it out with a can of compressed air.
  • If there is nothing blocking the memory card slot, the card may be inserted backwards.
Memory card is broken or damaged
  • If the memory card has been physically damaged, it may no longer fit into the camera, and will need to be replaced.
  • If the memory card has become corrupted, it may be necessary to reformat it.
Battery compartment will not close
There may be an obstruction
Maintenance
Cleaning the lens
Wade Harkins
crwdns2935283:002/06/12crwdne2935283:0
25 crwdns2915208:0crwdne2915208:0
James Madison, Team 3-3, Klein Spring 2012 crwdns2935289:0James Madison, Team 3-3, Klein Spring 2012crwdne2935289:0
JMU-KLEIN-S12S3G3
crwdns2935297:048crwdne2935297:0
crwdns2936753:030crwdne2936753:0 59
crwdns2959996:0crwdne2959996:0 3,345
