crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Camera Will Not Turn On
Your camera simply will not turn on
Drained Battery
The batteries are most likely out of charge. Try replacing them.
LCD Screen Damaged
Your camera may appear to be off because the screen is not active. However, the screen may simply be damaged. If the indicator light shows the camera is on, but nothing appears on the screen, you may need to replace your LCD screen.
Camera Turns Off Unexpectedly
Your camera turns off suddenly, when you do not intend it to
Drained Battery
Your batteries may be out of charge. Try replacing them.
Sensitive Power Button
This camera is known to sometimes have an overly sensitive power button. Make sure your grip when using the camera keeps all your fingers away from the button.
Out of Date Firmware
Your firmware may be out of date. Seek an update. Click here to download the OLYMPUS Digital Camera Updater. Once the software is installed, follow these steps to update the firmware:
  1. Before you begin
    1. Make sure you are logged into your computer with administrative privileges
    2. Make sure you are connected to the internet
    3. Make sure the camera has plenty of power
    4. Remove the memory card
    5. Connect your camera to the computer using the USB cable that came with it.
    6. Power the camera on
  2. Open the OLYMPUS Digital Camera Updater.
  3. Follow the on screen prompts to complete the update.
  4. Wait for the update to complete.
  5. Disconnect the camera.
  6. Close the updater.
Sleep Mode
If your camera's screen turns off, but the lens does not retract, the camera most likely entered sleep mode. This occurs after 3 minutes of inactivity. To wake the camera, simply press the shooting mode button, labelled with a red camera symbol.
Cannot Find Photos
You cannot find photos you have recently taken with your camera
Camera Loads from the Wrong Memory
If you took the photos without a memory card inserted, remove any inserted memory cards, and restart your camera. Your pictures should be visible.
Memory Card Locked
If you took the photos with a memory card inserted, check that the card is not locked. Power down the camera, and remove the card. On the side, there will be a small plastic slide switch. Make sure the switch is not in the LOCKED position. Then reinsert the card, and restart the camera. Your pictures should be visible.
Photos Not Saving to SD Card
Your camera will not save the photos you take to an inserted SD card
Full Memory Card
Your memory card may be full. Try downloading your pictures to a computer, or deleting images you no longer want.
Memory Card Locked
Check that your memory card is not locked. Power down the camera, and remove the card. On the side, there will be a small plastic slide switch. Make sure the switch is not in the LOCKED position. Then reinsert the card, and restart the camera. Your camera should now be able to save to the SD card.
Wrong Type of SD Card Inserted
Make sure you are not using a high-capacity SD card, as these require special interfaces.
Memory not Formatted Correctly
Format your SD card while it is in the camera. Go to setup, and run the memory format function. This process may take a few minutes to complete. This will delete all photos on the memory card, so make sure you remove any photos on the card first.
No Photo Taken When Shutter Triggered
The camera is powered up, but will not take photos when you push the button
Camera in Sleep Mode
Your camera may be in sleep mode. To wake the camera, simply press the shooting mode button, labelled with a red camera symbol.
Flash Recharging
Your flash may be recharging before taking another picture. Wait until the flash icon on the screen stops blinking.
Full Memory
Your camera's memory card may be full. Try downloading your pictures to a computer, or deleting images you no longer want.
Pictures Appear Washed Out, or Saturated with Whiteness
Your pictures are monotone, or too white
Bright Lights Overpowering the Image
This model of camera does not handle overly bright background lights. Remove lights or relocate if possible.
Invalid Pixels in the Image Sensor
Your image sensor may have some broken pixels. In the camera menu, go to setup, and run the "Pixel Mapping" function. The process will take a few moments to complete. If this does not work, try replacing the image sensor.
Visual Defects in the Image
Your images do not appear as they should on the LCD screen
Your image sensor may have improperly mapped pixels . In the camera menu, go to setup, and run the "Pixel Mapping" function. The process will take a few moments to complete.
Strong backlighting can interfere with image capture. Remove or avoid excess light when possible.
Damaged LCD Screen
Your screen may be broken or damaged. Try replacing it.
Damaged Image Sensor or Lens
The image sensor or lense of the camera may be broken or damaged. Try replacing the lens assembly.
Flash Not Working
Your camera's flash will not work
Flash Deactivated
May sure your flash is turned on. You can manually turn it on by pressing the button with the flash symbol on it and selecting the desired mode. The symbol looks like a lightning bolt-shaped arrow.
Flash Damaged
If your flash is on, but does not activate, you may need to replace it. Follow this guide for help.
Who Knows?
crwdns2935283:003/24/15crwdne2935283:0
104 crwdns2915208:0crwdne2915208:0
Baylor, Team 6-4, Shaver Spring 2015 crwdns2935289:0Baylor, Team 6-4, Shaver Spring 2015crwdne2935289:0
BU-SHAVER-S15S6G4
hi i have looked at the above but still cannot retreve my photos the camera will not allow
me to reset the dat date ect can you help
family sanders - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 54
crwdns2959996:0crwdne2959996:0 3,590
