crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Nook won’t power on
Nook will not turn on and does not respond to touch.
Nook is not charged
Locate the charging port at the bottom of the Nook. Plug in the micro USB cable to the charging port. Plug the power adapter into a wall socket. Let the device charge for 2-3 hours. Do not turn off the device while it’s charging.
Charger is broken
If your Nook still isn’t charging, the problem may be the charger itself. Inspect the charger for any visible damage, such as visible wires or discoloration. Try replacing the micro USB charging cable or power adapter.
Battery is faulty
If your Nook still fails to charge, the battery may be the problem. Try replacing the battery using this Nook BNRV300 Battery Replacement Guide.
Motherboard is faulty
If your Nook does not power on after trying the previous instructions, the problem may be the motherboard. Try replacing the motherboard using this Nook BNRV300 Motherboard Replacement Guide.
Nook screen is malfunctioning
Nook screen is unresponsive/frozen, or responds even without being touched.
Dirty screen
If your screen is dirty, the Nook may not respond properly. Power off your Nook by holding the power button for about 5 seconds and select the “Power Off” option. Then wipe the screen using a soft and dry cloth. Hold the power button for about 2 seconds to turn the Nook back on.
Low battery
If your battery is too low, the Nook may not respond properly. Try charging your Nook. Locate the charging port at the bottom of the Nook. Plug in the micro USB cable to the charging port. Plug the power adapter into a wall socket. Let the device charge for 2-3 hours. Do not turn off the device while it’s charging.
Device needs a restart
If your Nook screen is still malfunctioning, then you may need to restart the device. Hold the power button for about 5 seconds and select the “Power Off” option. Hold the power button for about 2 seconds to turn the device back on.
Broken screen
If the above solutions do not fix your screen malfunctions, then you may need to replace the screen. Use this Nook BNRV300 Display Replacement Guide to replace the screen.
Nook will not connect to Wi-Fi
Wi-Fi symbol is not visible and device will not connect to the internet.
Wi-Fi is not enabled
Your device may not connect to Wi-Fi because it has not been enabled. Click the '“n” home button. A menu will appear at the bottom of the screen. Select “Settings” and tap “Wireless” from the menu. Select the check box to turn on Wi-Fi, and choose a wireless network.
If your Nook still won’t connect to Wi-Fi, the signal may need to be reset. Hold the power button for about 5 seconds and select the “Power Off” option. To power on the Nook, press and hold the power button for about 2 seconds.
Problem with router/modem
If your Nook still cannot connect to Wi-Fi, then there may be an issue with your router/modem. Power off your Nook by holding the power button for about 5 seconds and select the “Power Off” option. Then power off the router and/or modem. Power on the router and/or modem after 30 seconds. Then power on your Nook by pressing and holding the power button for about 2 seconds. If your Nook still cannot connect to Wi-Fi, check with your service provider for possible issues.
Device Needs a Firmware Update
If firmware has not been updated since 2018, refer to the following guide on the Barnes & Noble website to attempt to fix:
https://help.barnesandnoble.com/hc/en-us...
Nook fails to charge
Nook battery will not charge even when connected to the charger.
Faulty wall outlet
If you Nook will not charge, the wall outlet may not function properly. Try moving the power adapter to charge your Nook at a different wall outlet.
Faulty charger
If the Nook does not charge with the current micro USB charging cable and power adapter, the cable may be broken. Try using a different micro USB charging cable. As your device gets older, certain cables may fit loosely in the charging port. Make sure the charger fits snugly in the charging port.
Dust in charging port
Your Nook may have debris in its charging port which prevents it from charging properly. Look into the port and gently puff air into it to remove any dust. If this does not work, carefully pick out the debris. Then try charging your Nook again. Locate the charging port at the bottom of the Nook. Plug in the micro USB cable to the charging port. Plug the power adapter into a wall socket. Let the device charge for 2-3 hours. Do not turn off the device while it’s charging.
Dead/bad battery
If your Nook still fails to charge, the battery may be dead or faulty. Try replacing the battery using this Nook BNRV300 Battery Replacement Guide.
Nook will not respond to button touch
Buttons are broken or unresponsive and/or the screen will not respond.
If the buttons are unresponsive, the device may need a soft reset. Hold the power button for about 5 seconds and select the “Power Off” option. To power on the Nook, press and hold the power button for about 2 seconds.
Clean/replace buttons
If the power button still doesn’t respond, it may need to be cleaned or replaced. In order to remove the power button for cleaning/replacement, see this Nook BNRV300 Power Button Replacement Guide.
To clean the “n” home button, wipe over it with a microfiber cleaning cloth. This button is internally attached to the front cover frame, and cannot be removed for cleaning/replacement.
Emily Tracy
crwdns2935283:010/03/19crwdne2935283:0
437 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G1, Al-Hmeyrat Fall 2019 crwdns2935289:0Eastern Washington University, Team S1-G1, Al-Hmeyrat Fall 2019crwdne2935289:0
EWU-AL-HMEYRAT-F19S1G1
crwdns2935297:059crwdne2935297:0
Nook will not open books. Msg =
Error opening book
sorry, cannot open this book. This book will be
redone loaded later.
Donna Heinzl` - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 6,101
