crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device won't charge
No matter what you do, you can't get your device to charge.
Wrong charging adapter
Before delving into the guts of your Power Panel, the Nokero P102 comes with five charging adapters. Make sure the adapter fits your device properly.
Indirect sunlight
If your device won't charge make sure sunlight is not being filtered by clouds or a window. The Power Panel needs direct sunlight to charge your device.
Dirty panel
Dirt and dust can obstruct sunlight. Make sure the solar panel is clean.
Broken Solar Panel
If your solar panel is cracked or scratched, you will want to replace it.
Faulty USB port
If the device won't charge, an unlikely cause is a faulty USB port. To fix this you will need to open the device to check that nothing is disconnected. You may need to replace the USB port.
Power Panel won't hold a charge
After bathing in direct sunlight, the panel won't provide sufficient charge.
Non-functioning capacitor
If the panel won't transfer charge, see the troubleshooting guide for "Device won't charge". If the problem persists, you may have a capacitor that simply doesn't work. To fix this you will need to open the device to check that nothing is disconnected. You may need to replace the capacitor.
LED indicator is not turning on
Your LED is not illuminated, even though your device is charging.
Indirect sunlight
The LED only lights up when exposed to ample amounts of sunlight. The device is designed to store power so that it can charge your device anywhere. If the LED still does not light up in direct sunlight then you will need to replace the light.
Nicholas Orr
crwdns2935283:001/20/15crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-3, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 9-3, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S9G3
crwdns2935297:036crwdne2935297:0
crwdns2936753:030crwdne2936753:0 47
crwdns2959996:0crwdne2959996:0 539
