Nokero SunRay Pro Power Panel Capacitor Replacement
crwdns2869540:0crwdne2869540:0: 822
2
22
90
822
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: 15 - 30 crwdns2931279:0crwdne2931279:0
Not being able to charge your device may mean you have a bad capacitor. Follow these simple steps to get yours replaced.
    1. Nokero SunRay Pro Power Panel Capacitor Replacement, Front and Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn over the device so that the back of the device is facing up.
    2. Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the first plastic opening tool along the side to pry open the case.
      • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
      • Use a second plastic opening tool to help separate the remaining seams.
    3. Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
      • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
    4. Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
      • Remove the solar panel and circuit board from the front case.
    1. Nokero SunRay Pro Power Panel Capacitor Replacement, Capacitor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the soldering station to desolder the two contact points around the connections of the capacitor to loosen the metal.
    2. Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the capacitor through the circuit board to remove it.
Nicholas Orr
crwdns2935283:001/20/15crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-3, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 9-3, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S9G3
crwdns2935297:036crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 90
crwdns2959996:0crwdne2959996:0 822
