Buttons are sticky
When you press on a button, it takes longer than usual for it to pop back up.
Dirt underneath button
Before taking apart your controller, make sure that there isn't any residue that may cause the button to stick to the controller. If this is the case, simply use a pin or toothpick to scrape away at the residue. This should eliminate most of the residue. Next, use a solvent such as rubbing alcohol on a cotton swab to wipe away the rest of the 'gunk'.
Rubber backing is damaged
There's a possibility that the rubber backing responsible for making the buttons spring back up is damaged. Prepare your screw driver! You're going to have to replace it.
Controller has a mind of its own
Even though a button or joystick is not pressed, the console continues to register input, possibly causing a character to move uncontrollably or attack repeatedly
Dirty controller
Sometimes dirt can activate buttons without user input. If this is the case, you may or may not have to open up the controller, depending on the amount of dirt. Before getting your hands dirty and taking apart the entire controller, wipe around the button with rubbing alcohol and cotton swabs in a circular motion. If the problem persists, go ahead and take it apart to clean it.
Joystick/Analog trigger is tilted while powering on the console/controller
If it seems as though your character won't stop running around, the L/R buttons refuse to be pressed, or your screen keeps going around in circles, your joystick might be set in a non-neutral position. The issue may be that you moved the the joystick before starting the game. In certain situations, this can cause a communication error between the game and the controller, causing it to malfunction. A simple fix is to not touch the joystick until the game has started. If you're unfortunate enough to have suffered this calibration issue, there are two methods that will quickly solve this: 1. Unplug the controller and plug it back in with all analog axes in neutral position. This resets the calibration for each analog axis, thus solving this issue. 2. This method is probably the lesser-known of the two, but works equally well. Simply press and hold the X, Y, and start/pause buttons simultaneously for 3-5 seconds without tilting any analog sticks or pressing either trigger. This resets all of the analog axes in the same way that resetting the controller via unplugging does- essentially, it reboots it.
Bad bootup
Your console may have run into an error while booting. Errors frequently occur when the console isn't properly started. First, turn off and unplug your console, then wait about 30 seconds. This ensures all the memory from your previous gaming session has been cleared. After sufficient time as passed, go ahead and turn your console back on.
Rogue Joystick
The joystick stays tilted even after you take your thumb off of it
Dirt underneath joystick
This is a mechanical problem. Unfortunately that means you have to do some dirty work. Start by removing the joystick. Then give it a deep cleaning with rubbing alcohol.
The Joystick is not correctly attached to the motherboard
Don't worry, this isn't as scary as it sounds. Try repairing the joystick.
GameCube does not recognize controller
When you turn the GameCube on, it says "No Controller"
Bad bootup
Sometimes, the console may not recognize a controller if it runs into an error while booting. Errors frequently occur when the console isn't properly started. First, turn off and unplug your console from the wall, then wait about 30 seconds. This ensures all the memory from your previous gaming session has been cleared. After sufficient time as passed, turn your console back on.
Bad connector or cable
The first thing you will want to do is try plugging a different, working controller into the same port. If the problem persists, you may have a bad port. In that case, please refer to the GameCube device page to find a solution. Next, try plugging the original controller with the problem into a different port. If problems persist, it may be a problem with the cable or connector. If you think the issue is a bad cable, don't fear! A bad cable is better than a bad port! Make sure your cable is not twisted up or knotted. The easiest and often most successful fix to a cable not being recognized is to simply blow air into the end of the cable. These cables can dusty very easily and oxidation on electrical leads can cause controller recognition problems.
Won't rumble
The controller won't rumble even when it should
The game does not support rumble
Some games simply do not support the rumble function. Check the instruction manual provided with the game to see if haptic feedback is supported.
Check Contact Of The port
The port contact where the controller goes may be dirty and need cleaning to make contact fully. Rumble should work after that if no other controller works with rumble in the same slot.
Bad motor
Unfortunately, motors sometimes fail. A motor can be fried from over use and no longer functional. At this point, the best you can do is to replace the motor.
Your controller is a WaveBird
WaveBirds (The wireless version of the GameCube controller) don't have the rumble function. The feature was removed to increase the controller's battery life, and perhaps, given the location of the battery compartment, to give the batteries enough space without making the controller too bulky.
Back to Device Page
Rachel Willis
crwdns2935283:001/14/13crwdne2935283:0
161 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team 19-44, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 19-44, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S19G44
crwdns2935297:0108crwdne2935297:0
crwdns2944067:015crwdne2944067:0
Under the "Rogue Joystick" problem, the second solution that advises the user to remove the joystick is redundant. It is unnecessary to instruct to reinsert the joystick because that step is already included in the linked installation guide.
By re-wording that solution, you can avoid confusing the reader.
Andre Nguyen - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
im using a wireless controller so what should i do then? it wont connect
Gabriel Green - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My GameCube has not experienced any problems at all until now, but while my sister was playing WindWaker the console started resetting itself repeatedly until it just turned off. The fan was still going though. Later I checked it out. It will turn on still, but once I plug the controller in it turns off, but the fan still runs. I'm not sure if it's the controller or not, but I can't tell because I only have one. Does anyone know what to do?
Jer King - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I had the same problem, check if the cable is exposed, I had to cut the cable and rewire the cables inside.
Ramon Zamudio - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Sticky buttons are not caused by "gunk" directly underneath the buttons, barely any dirt ever gets there. What causes the stickiness is the dirt that accumulates around the SIDES of the buttons, and along the sides of their hole. Clean that up with alcool on a cotton swab and that'll fix most sticky button problems.
Michel Drolet-Gravel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 65
crwdns2936753:030crwdne2936753:0 238
crwdns2959996:0crwdne2959996:0 97,421
