Nintendo GameCube Controller Rumble Motor Replacement
crwdns2869540:0crwdne2869540:0: 19K
2
45
193
18,585
crwdns2955950:0crwdne2955950:0: 4
crwdns2960004:04crwdne2960004:0.
crwdns2959984:0crwdne2959984:0: 3
crwdns2959974:03crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 5
crwdns2959982:05crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 5 - 7 crwdns2931279:0crwdne2931279:0
crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
This guide is all about installing the rumble motor. The rumble motor is responsible for the vibration you feel in your controller during certain game actions. You may want to use this guide if your controller won't rumble.
    1. Nintendo GameCube Controller Rumble Motor Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the controller (buttons down) on a solid surface.
      • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    2. Nintendo GameCube Controller Rumble Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift the back panel up, separating it from the front panel.
      • Some of the buttons may fall out if they are knocked around.
    1. Nintendo GameCube Controller Rumble Motor Replacement, Z Button: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo GameCube Controller Rumble Motor Replacement, Z Button: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grab the Z-button by the peg with tweezers and lift it out of the controller.
      • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    1. Nintendo GameCube Controller Rumble Motor Replacement, Circuit Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully unhook the cable that is looped around the peg.
    2. Nintendo GameCube Controller Rumble Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the circuit board out of the controller.
      • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
    1. Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Press the tip of the soldering iron against one of the leads and wait until solder is viscous. Carefully pull wire away from lead.
      • Repeat for the second lead and wire.
      • During reassembly, solder the white wire to (+) lead on the right side, and the black wire to the (-) lead on the left side.
      • For more information, please refer to this soldering guide.
    2. Nintendo GameCube Controller Rumble Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using tweezers, unhook the wires from the small black bracket keeping them attached to the circuit board.
    3. Nintendo GameCube Controller Rumble Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the motor out of the bracket.
      • Remember to not pull by the wires! This can make your repair a lot more complicated.
Sean Michel
crwdns2935283:001/14/13crwdne2935283:0
2,768 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-44, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 19-44, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S19G44
crwdns2935297:0108crwdne2935297:0
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 193
crwdns2959996:0crwdne2959996:0 18,585
