crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
crwdns2959928:0crwdne2959928:0 ↓This guide will take you through the steps of removing the joystick. This will come in handy if you have a rogue joystick
Place the controller (buttons down) on a solid surface.
Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
Gently lift the back panel up, separating it from the front panel.
Grab the Z-button by the peg with tweezers and lift it out of the controller.
Carefully unhook the cable that is looped around the peg.
Lift the circuit board out of the controller.
Grab the base of the grey cover and pull it off.
crwdns2935229:032crwdne2935229:0
crwdns2947412:013crwdne2947412:0
Great guide, but I'm looking to buy replacement joysticks and I can't find them anywhere. Where would I find those?
Joe Freedman - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When I removed the joystick it would come off. The plastic was stuck too hard to the joystick so I accidentally broke it in half. Is there anyway to glue it back together?
Mattias Wirsenius - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
@Tyler Lovejoy - That's already part of the controller.
@Joe Freedman - Try Amazon.com
@Mattias Wirsenius - At this point it would be best to buy a new controller.
builderman1q2w3e4r - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This guide is quite unhelpful; it tells you how to remove the stick but not how to repair it. My controller's joystick has sunken into the controller and stays slightly tilted if i move it to the right. Yet when I go to the "rogue joystick" portion of the troubleshooting guide, it tells me to repair the joystick if it's not correctly attached to the motherboard. Seriously, there needs to be a more in-depth guide if such repairs are possible.
J DC - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
without taking the controller completely apart, pull the joystick straight up with your hand
McRedstoneYT - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
