NOTE: If you have a question about the Linksys E1200 Wireless Router that is not addressed on this troubleshooting page, please go to the following troubleshooting link for additional information.
Troubleshooting page
Lost connection or slow connection
If you are losing connection or your connection is slowing down you may need to take steps to prevent overheating. Overheating is a common issue with this device as they need proper ventilation. It can also be caused from overloading. For steps to prevent overheating follow this link.
Linksys e1200 wireless router Maintenance to Prevent Overheating
Interior damage of device
If your device is not working properly and you think it might have to do with the hardware itself, maybe it had been dropped or damaged or you hear something rattling within, you can use the following link for general disassembly of your device.
Disassembling the Linksys E1200
Ethernet port works randomly or not at all
If your device is not powering on, it may be due to the Ethernet connection. There are 4 ports and 1 or more could be damaged or loose. It may also have to do with the connection itself or the cable. If you are experiencing difficulties connecting to the Ethernet port follow the link for instructions on how to repair it.
Linksys e1200 Wireless Router Ethernet Port Replacement
Adaptor cord is damaged
If the adaptor that came with your Linksys E1200 has a damaged cord, please see the following link to learn how to repair the adaptor.
Linksys E1200 Router Power Adapter Replacement
Device is running slow
If your device is running slow and you want to maximize its speed, you may need to clean the device. Sometimes dusts and hairs can cause the device to slow down or overheat even if the device isn't visibly dirty.
Natasha Fetzer
crwdns2935283:002/24/14crwdne2935283:0
189 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Michigan Tech, Team 5-4, Lauer Spring 2014 crwdns2935289:0Michigan Tech, Team 5-4, Lauer Spring 2014crwdne2935289:0
MTU-LAUER-S14S5G4
crwdns2935297:048crwdne2935297:0
crwdns2944067:05crwdne2944067:0
crwdns2942667:0crwdne2942667:0 6,388
