crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Not-charging Optimus F3
Bad Charging Cable
A broken charging cable could be a cause of the problem if your phone is not getting charged. To make sure your charging cable works, you can experiment with your charging cable by trying to charge another phone.
Dust Clogging the Charging Port
When the device is not charging you might want to clean up the port by blowing out the dust inside the port. Sometimes dust and/or debris can hinder charging.
Bad Charging and Data-Transmission Port
If either changing your charging cable or cleaning the port do not help your device to get charged, you might want to replace the charging/data transmit port by replace the second part of the mother board. You can check out our LG Optimus F3 Charging port unit Replacement here.
No Sound From Headphones
Broken Headphones
If there is no sound from the headphones, first you need to make sure the headphone unit works. Try it on another device, headphones usually fits to any kind of device. If the sound does not come out again, the headphone unit is broken and you would need a new one.
Software Corrupted
Sometimes the software in the device affects the performance, so you might want to update your device software to the newest version.
Bad Headphone Jack Unit
If all else fails and you need to replace the headphone jack, you can check out our LG Optimus F3 Headphone Jack Replacement here.
Camera not working
Software out of date
You can simply update your software to the newest software package when the camera unit is not functioning correctly.
Bad Camera Unit
You can simply replace the camera unit. You can check out our LG Optimus F3 Back Camera Replacement here.
No sound from the Speaker
System software corrupted
Bad Speaker Unit
You can simply replace the speaker unit. You can check out our LG Optimus F3 Speaker Replacement here.
Jonathan Fang
crwdns2935283:010/28/15crwdne2935283:0
356 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-5, Miles Fall 2015 crwdns2935289:0UMass Dartmouth, Team 1-5, Miles Fall 2015crwdne2935289:0
UMASSD-MILES-F15S1G5
crwdns2936753:030crwdne2936753:0 33
crwdns2959996:0crwdne2959996:0 881
