crwdns2959928:0crwdne2959928:0 ↓This is a replacement guide on how to replace your back camera unit on your LG Optimus F3.
Remove the battery cover. Unsnapping each corner will allow the cover to come off.
Unscrew the ten 1.0 mm screws on the back.
Separate the rear plastic case by inserting the opening tool between the seams on all sides.
Located at the top left corner is the camera unit.
Use a plastic opening tool to detach the connector between the back camera and the motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tweezers to remove the camera by pinching the sides and carefully pulling up.
