crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The LG Grace won't boot or randomly shuts down
The phone doesn't boot up or may sometimes shutdown at random
Battery Not Seated Correctly or Dead
  • Check to ensure that a battery is seated properly inside the phone and that it is charged. This phone has a easily removable battery and you may take it out to clean the terminals and charge it on an external charge to ensure that it's working.
  • If phone still will not turn on, it is likely one of two issues
Faulty Motherboard
  • The motherboard may be bad, in which case all is not lost. It may be a little involved, but this guide will walk you through how to replace your motherboard. Please note, by doing this you will more than likely lose access to the data stored on the phone. While not in the scope of this guide, it's advised you seek out a technician to recover the data from the faulty motherboard if that data is valuable to you.
The device is not charging
When you plug in the phone, it doesn't appear to be charging.
Battery Not Seated Correctly or Bad
  • Try a different charging cable/block. Ensure that it truly is an issue with the phone before attempting to replace components in your phone.
Faulty Charging port
  • If it still won't charge, the most likely culprit is the charging port. It can get clogged with debris, so first blow it out with compressed air or otherwise ensure that the port is free of debris. However, the pins inside these ports can also be fragile and when damaged a new port is needed. This guide will walk you through how to do that.
The screen flickers, goes dark or is unresponsive to touch input
Screen isn't functioning properly
Display Drivers Bad
  • A hard reset is also always advised in these situations as it frequently resolves smaller software issues.
  • Software solutions are out of the scope of this guide, but if the display drivers themselves are bad a factory reset may work. If it doesn't please consult an expert.
Faulty LCD Screen
  • Please ensure that the screen is clean and that your hands are clean as well; any buildup on wither could interfere with the screens ability to read your inputs.
  • If neither of those solutions helped, the LCD screen may be damaged and require replacement. This guide will walk you through how to replace the faulty screen with a new one.
The the device's camera is blurry, unable to focus or otherwise malfunctioning
The camera isn't taking photos properly, either blurry or completely black
Faulty Camera
  • Wipe down the lens with a microfiber cloth
  • Make sure that it's not simple environmental factors IE: attempting to take a photo of something too close for it to properly focus on.
  • After narrowing it down to a hardware problem, you may want to replace the camera all together. If that's the case, this guide can instruct you on how to remove and reinstall the rear facing camera in the LG Grace.
The device's rear speaker doesn't sound right
The rear speaker either isn't playing audio or it's muffled
Bad Audio Drivers
  • Hard reset to ensure that if it's a simple software bug it has the opportunity to fix itself.
  • Software solutions are out of the scope of this guide, but if the audio drivers themselves are bad a factory reset may work. If it doesn't please consult an expert.
Potential User Error
  • Please check to make sure neither your phone nor the media you are attempting to listen to are muted.
  • please take off the back of your phone and ensure that the speaker isn't covered in a layer of lint or something else that may impede it's functioning
Faulty Rear Speaker
  • the rear speaker is responsible for playing audio for basically anything that isn't a call and doesn't go though the earpiece speaker. This component malfunctioning can leave you unable to make use of many of your phones functions. If you have checked that it's not one of the simple solutions above, this guide will teach you how to remove this component and replace it with a functional one.
Dylan Kent
crwdns2935283:009/09/23crwdne2935283:0
679 crwdns2915208:0crwdne2915208:0
University of New Orleans, Team 4-3, McDonald Fall 2023 crwdns2935289:0University of New Orleans, Team 4-3, McDonald Fall 2023crwdne2935289:0
UNO-MCDONALD-F23S4G3
crwdns2959996:0crwdne2959996:0 354
