Phone Won't Turn On
Your phone won't turn on, even when plugged into a power source.
Malfunctioning Battery
Remove the battery from the phone, wait five minutes, then reinsert and try to turn on the phone. If this doesn't work, try replacing the battery with a new one.
Malfunctioning Motherboard
You will need to replace the motherboard.
Screen Response Is Slow Or Screen Is Frozen
The Screen is slow to update after pressing a key or is completely frozen.
Too Many Applications Running
If you press a button and the response lags in time, or there is no response at all, this may mean there are too many applications running at the same time. Try ending all open applications, then power off/on the phone.
Temporary Phone Freeze
Power off the phone then power it back on.
Black/Dim Screen
The phone is on but the screen is darker than it should be.
Damaged LCD screen
The LCD screen will need to be replaced.
Cracked Screen
The screen of the phone has cracks or other damage that blocks visibility
Cracked Outer Glass
If the display underneath the glass is still functioning, then the outer glass should be replaced.
Damaged LCD screen
Keyboard Doesn't Function Correctly
The phone will turn on, and the screen displays correctly, but the QWERTY keypad is either unreadable or not functional.
Letters Have Faded
If the letters on the keyboard are no longer readable from repeated use, you will need to replace the keyboard.
Buttons Are Unresponsive
If the phone will not respond to the keyboard buttons, and you have tried powering off/on your phone, this may be an indication that the keypad sensors are not working. You will have to replace the motherboard.
Nick White
crwdns2935283:010/18/13crwdne2935283:0
866 crwdns2915208:0crwdne2915208:0
Clemson, Team 13-1, Benson Fall 2013 crwdns2935289:0Clemson, Team 13-1, Benson Fall 2013crwdne2935289:0
CLEM-BENSON-F13S13G1
crwdns2935297:096crwdne2935297:0
My keyboard buttons were not working but all I did was take out the battery, wait 30 secounds, put it back in and turned it on. Keypad worked perfectly after.
Sam - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2959996:0crwdne2959996:0 5,474
