Phone Won't Turn On
No signs of life.
Phone Isn't Charged
If your phone is not turning on, try connecting it to the charger for several minutes. If your phone isn't charging or is still not turning on, read on.
Blocked Charging Port
If your phone won't turn on try plugging in a different charger or battery. Also try plugging in your charger to a different outlet or USB port. Make sure the charging port on the phone is clear of debris.
Wrong Charger
Sometimes different chargers aren't compatible with the phone even though they may appear to fit. Make sure the charger you're using is manufacturer-approved.
Battery Won't Hold Charge or Drains Too Quickly
It dies way too fast.
Bluetooth is Turned On
Access the phone menu and turn off Bluetooth capabilities. Bluetooth drains the battery so turning it off when not in use will help preserve battery life.
Brightness is On Too High
Go to display settings and set brightness and display timeout option to lowest usable level.
Live Wallpapers are Enabled
Disable live wallpapers and widgets. Live wallpapers are pretty and all, but in return they devour your battery life.
Dead Battery
When all else fails replace the battery: Battery Replacement Guide
Phone Won't Open or Close
Phone is Dirty
Debris can prevent the phone from opening and closing properly. Try cleaning it out.
Slider is Broken
If it's impossible to clean the phone or it still isn't opening, replace the phone slider.
Display is slow
Restart Phone
Restart the phone by holding down the "end call" button until the screen goes black. Wait for a few minutes, then hold the power button down again until the screen turns on.
Full Memory Storage
Check the memory storage to see if it is at or near full capacity. If it is, consider deleting large files and applications. If you want to keep the files then transfer them to your computer or buy a larger SD card if your phone has one.
If this fails, try turning your phone off and replacing the battery. Then turn your phone back on.
LCD Screen is Broken
It didn't survive the fall!
Cracked LCD Screen
Refer to our LCD screen replacement guide.
"Insert SIM" Error Message Appears on Screen
Emergency calls shouldn't be my only option!
SIM Card Inserted Incorrectly
Turn off the phone, remove battery cover and battery, and make sure the SIM card is connected well. Then, restart the phone.
Audio Isn't Working
Can you hear me now?!
Phone is in Silent Mode
Turn up the volume by pressing the "up arrow" button on the right side of the phone.
Speaker is Blocked by Phone Case
Remove your phone case and check to see if the sound improves. Sometimes phone cases are poorly made and cover up important components.
Speaker is Damaged
If all else fails, replace the speaker(s). See if you can distinguish which speaker is defective.
If it is the front speaker: Click here.
If it is the back speaker: Click here.
Photos/Videos Will Not Save
This thing won't hold all of my stuff!
Full Memory Storage
Get rid of the old to make room for the new or move photos/videos to an SD card or computer.
Password is Forgotten
I just can't remember.
Locked Out of Phone
Check to see if you have the password on record somewhere, or ask a friend or family member who has access to the phone.
If all else fails, perform a factory reset. This is your very last resort. A factory reset will delete all the data on your phone, including contacts, messages, pictures, videos, and other saves.
Refer to AT&T's Master Reset Guide.
Phone Keys Won't Work
I'm pressing as hard as I can!
Debris Under the Keys
Try cleaning underneath the phone keys.
Keyboard is Broken
Are the buttons sticky and unresponsive? Remove the keypad and clean underneath the rubber number pad.
Connection is Unclear/Inaudible in Certain Areas
We're losing connection.
No Service in Your Area
Move to another location with a stronger signal and try again. Some areas in the country might not be covered by your provider. Look for areas with more bars.
Kathrine Muirhead
crwdns2935283:010/15/13crwdne2935283:0
353 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-27, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 4-27, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S4G27
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 46
crwdns2959996:0crwdne2959996:0 1,685
