crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Coffee Tastes Metallic or Bitter
Coffee from Keurig tastes strange.
Calcium Build Up
If your coffee tastes bitter, your Keurig’s water lines may have calcium buildup and require cleaning.
To clean your water lines, you need the following:
  • 48oz of Distilled vinegar
  • A large coffee mug
  • A cloth or rag
To begin cleaning your Keurig, follow the below steps:
  1. Empty your Keurig’s reservoir of water and clean the walls generally with soap and water
  2. Clean out your K Cup holder, removing grime and coffee grounds
  3. Fill your water reservoir up to the fill line with distilled vinegar
  4. Place your coffee cup below the coffee dispenser
  5. Set your Keurig to the largest brew size, ensuring that no K Cup is inside the holder
  6. Run the largest brew size
  7. Dump the outputted vinegar from your coffee cup into your sink
  8. Continue running cycles until the reservoir is empty
Outdated Water Filter
If your coffee tastes metallic, it may be time to replace the water filter inside your water reservoir. Follow our guide on replacing your Keurig’s Water Filter.
Keurig Doesn’t Turn On
Keurig is unresponsive to the power button.
Dead Outlet or Blown Fuse
If your Keurig is unresponsive to power button presses, the outlet you are using may be malfunctioning.
Move your Keurig to a different area and try a new outlet.
Faulty Power Cable
If your Keurig is still not turning on, your power cable may be faulty. Follow our guide on replacing the Power Cable.
Keurig Not Brewing a Full Cup
Keurig is brewing a partially filled cup, less than expected.
Faulty K Cup
The K Cup brand you are using may be faulty, try brewing a cup of just water (without a K Cup inserted), and see if a full cup is poured. If a full cup is brewed, you should consider buying a new brand of K Cups.
Faulty Secondary Water Pump
If your Keurig is not brewing a full cup of coffee, you may need to replace the secondary water pump in your Keurig. A faulty water pump will prevent enough water from reaching your mug.
Follow our guide on removing the Secondary Water Pump here.
K Cup Holder Will Not Close
Lid will not close or opens again after closing.
Dirty K Cup Holder
If your K Cup Holder does not close or is jammed, it may need to be cleaned. Excess coffee grounds may be preventing the holder from closing. Follow our guide on removing and cleaning the K Cup Holder here.
Faulty K Cup
The K Cup you are using may be damaged or warped. Try grabbing a new K Cup.
Defective Lid Spring
If your Keurig's lid will not close or does not stay open, you may need to replace the spring underneath the handle.
Check out our guide on replacing your Keurig's Lid Spring.
Coffee Temperature is Low
Coffee brewed from the Keurig is luke warm or cold.
Calcium Build Up in Water Pipes
If the coffee from your Keurig is no longer hot, the water lines in your Keurig may need to be cleaned due to excess calcium build up.
  • A cloth or rag
William O'Brien
crwdns2935283:001/23/18crwdne2935283:0
500 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G3, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S1-G3, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S1G3
crwdns2944067:09crwdne2944067:0
Brew size will not light up.
Water automatically starts when power button pressed, and water is not hot.
Janice W Threatt - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Keurig K55 will not brew. Turns on and powers up but then the add water, heating and middle
cup bottom blinks blue and red. How do I fix this?
Taylor Hilborn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
how did you fix the problem? i have the exact same think . rdtold@yahoo.com
rdtold - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How did you fix this problem? My K55 is pushing out 2 separate little bits of water, then the lights light up just as you describe.
Janice - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my k155 commerical coffee maker worked great , today it would not run all it did was making chattering like gears not aligned ,, at the same time programing window white, going crazy that noise at start up is crazy. does anyone hear of this problem and fix. thanks.JOE
jkp61648 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 55
crwdns2959996:0crwdne2959996:0 8,561
