crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device Won’t Power On
The camera is not responding or will not power on
Dead Batteries
If your camera doesn’t turn on, then the batteries may be drained. Replace the batteries and try to turn the camera on again.
Backlight Broken
If one or more of the screens is not displaying anything, then there may be a problem with the backlight. Check to see if any of the other lights on the camera are on. Try switching between the front and back screens. If any of the lights or screens are on, then there is a problem with the backlight. Follow this guide to replace the LED screen.
Faulty Motherboard
If none of these other solutions work, by process of elimination, it is likely that you have a faulty motherboard. Follow this guide to replace the motherboard.
Device Won’t Connect to PC
When plugged into a computer, the camera does not respond to being connected
Drivers Out of Date
Ensure that the camera's drivers are up to date so that it may connect to a computer either by using the driver disc that comes with the camera or downloading drivers from the camera’s website and installing those.
Bad Wire
The cable used to connect the camera to a PC may be damaged or not functioning. First, check if the device is powered on. Next, check the microUSB to PC cable for any frayed or damaged wiring. If that’s the case, the cable may be unusable. If that is not the case, test the microUSB cable with a familiar device such as a smart phone or tablet. If the problem still persists, you may need a new microUSB to PC camera cable.
Mac Incompatibility
If video files read as corrupted when uploading to a computer, it is likely a result of unreadable file types. This camera creates .avi video files, which are unreadable for most Mac’s. Unfortunately, there is not an easy way to get around this. You can upload the files to another computer, convert them to from .avi to .mov files, and then transfer them to your Mac.
Flash Not Functioning
When taking pictures the flash function does not activate
Flash Function not Enabled
There are 3 types of flash settings; ‘Force Flash’ in which the flash operates in all conditions, ‘Auto Flash’ in which the camera determines when to use the flash, and ‘No Flash’ which disables the flash completely. If the flash does not work, be sure it is not in the ‘No Flash’ setting.
Camera in Macro Setting
Check the camera and make sure the macro/normal switch is not set to macro. These cameras disable flash function when taking macro pictures.
Burnt Bulb
If the camera goes through the motions of charging the flash before a photo is taken but does not emit light, the bulb is probably burnt. See this guide on how to replace the flash unit.
Faulty Flash Assembly
In the case that the bulb functions but the flash continues to not go off, the whole assembly might be bad. See this guide on how to replace the flash unit.
Trouble Switching Screens
The Camera does not switch between the two screens
Camera is in Video Mode
If the camera is in video mode, it may not switch between the two screens. Switch to portrait mode and try switching screens again.
Backlight Broken
If you are having trouble switching screens, then one of the backlights may be broken. Check to see if any other lights on the camera are on. While one screen is on, press the button to switch screens. If neither screen displays any image now, then it is likely a backlight issue. Follow this guide to replace the LED screen.
Display Frozen
The Camera's screen doesn't respond to input
Screen is Unresponsive
Frozen displays are an unfortunate reality of this model. Try rebooting the camera until the camera boots up and functions normally. Hold the power button for 20 seconds to soft reset the device. This generally fixes a frozen screen.
Zoom Not Functioning
The camera will not zoom in or out
Zoom Buttons Unresponsive
If the zoom buttons are unresponsive, there might be a problem with the internal gears in the lens. Replacing the entire assembly will be necessary. See this guide to replace the lens unit.
Wendy Jones
crwdns2935283:002/06/16crwdne2935283:0
225 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-6, Eyestone Spring 2016 crwdns2935289:0USF Tampa, Team 6-6, Eyestone Spring 2016crwdne2935289:0
USFT-EYESTONE-S16S6G6
crwdns2944067:05crwdne2944067:0
This information is great, however it does not provide any direction on how to 'enable' the flash when it may not be working, or 'enabled'. Can someone help us to figure out how to 'enable' it as it isn't working for us and I can't find in the settings. Thx! Mary
Mary Pabstel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my camra wont turn on but we have battries in it i put the sd card in the wrong way and now it wont turn on
Space Wolf - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
For some reason whenever I take a picture it doesn’t show it in the gallery. All it says is “File error” and I’m not sure what that means. After I take a picture it shows iton the screan for a second but then when I look at it in gallery it doesn’t show.
Chloe - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2959996:0crwdne2959996:0 2,664
