Ivation IVWPDC20Y Flash Bulb Replacement
crwdns2869540:0crwdne2869540:0: 661
2
19
86
661
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:030crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
Use this guide to replace the bulb on the flash if it is burnt out.
    1. Ivation IVWPDC20Y Flash Bulb Replacement, Flash Bulb: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
    2. Ivation IVWPDC20Y Flash Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Apply a plastic opening tool to each of the corners and gently remove the casing
      • The front casing is held down by adhesive and may require additional work to remove
      • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
    3. Ivation IVWPDC20Y Flash Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
    4. Ivation IVWPDC20Y Flash Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
      • These screws are very small and easy to strip so apply consistent pressure when removing them
    5. Ivation IVWPDC20Y Flash Bulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry off back outer casing using the black spudger or the blue prying tools
    6. Ivation IVWPDC20Y Flash Bulb Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully remove the screen from the silver casing using a prying tool or the black spudger
      • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
    7. Ivation IVWPDC20Y Flash Bulb Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently push out the pins holding the orange tape down using the pointy end of the spudger
      • Screen and orange tape should slip out as a whole
    8. Ivation IVWPDC20Y Flash Bulb Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
    9. Ivation IVWPDC20Y Flash Bulb Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver bit
    10. Ivation IVWPDC20Y Flash Bulb Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift the corner of the motherboard out
      • Everything should come out as one component free of the casing
    11. Ivation IVWPDC20Y Flash Bulb Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the soldering on the three wires holding the flash bulb
      • The wires are different colors: red, white, and black
Wendy Jones
crwdns2935283:002/06/16crwdne2935283:0
225 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-6, Eyestone Spring 2016 crwdns2935289:0USF Tampa, Team 6-6, Eyestone Spring 2016crwdne2935289:0
USFT-EYESTONE-S16S6G6
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 86
crwdns2959996:0crwdne2959996:0 661
