crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace the main rear-facing screen of the Ivation IVWPDC20Y camera.
With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
Apply a plastic opening tool to each of the corners and gently remove the casing
Remove the five silver screws from the inner casing using the PH00 screwdriver bit.
Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit.
Pry off back outer casing using the black spudger or the blue prying tools.
Carefully remove the screen from the silver casing using a prying tool or the black spudger.
Using the poker end of the spudger push gently on the black pegs holding the orange tape in place.
