crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Motor isn’t turning on
The motor isn’t spinning
Bad Power Cord
Check and see if the device is plugged in correctly (test multiple sockets). Does the power cord show any kind of exposure or bronze copper wiring? If so your power cord is most likely damaged and needs replacing. Refer to our power cord replacement guidefor help.
Damaged Motor
When using the pulse button does the motor make any noise. If it does the motor may be jammed or completely damaged. Check out the motor replacement guide for further assistance in fixing your motor.
Can't find Hamilton Beach 70740 parts
Where can I find Hamilton Beach 70740 parts?
Hamilton Beach Website
One resource to find replacement parts is the Hamilton Beach website. Under the Parts and Accessories tab you can find components such as lids, bowls, blades, etc. For further inquiries you can access the Hamilton Beach Contact Us page.
Blade does not cut well
Chopping/mixing blade is dull
Blade Sharpener
You may start to notice that sliced/chopped food are not as fine as they once were. If your blade doesn't cut as well as it used to, you may consider a blade sharpener. It can be done by hand using a sharpening stone or by utilizing an aluminum oxide grinding wheel.
Blade Replacement
Another way to get more efficient cutting blades is to replace them entirely. We recommend visiting our blade replacement guide, and you can find some parts and accessories at the Hamilton Beach website.
Device keeps jamming
Food stuck in blades
Food Build Up
Depending on the type of food that is being chopped/mixed the motor may experience increased resistance due to food residue. A common symptom of jamming is slow rotating blades. If possible make sure you are cleaning your mixing blade after each use. Make note that the Food Processor should not be used on grinding grain, coffee beans, spices, frozen meat, dough, or ice.
Buttons not working
Keys are unresponsive
Device Power
Make sure the Hamilton Beach is plugged in correctly. The device must be plugged in order to operate.
Faulty Buttons
When using the center pulse switch, if the device functions at one speed setting while malfunctioning at the other, this is a strong indicator that the switch is damaged and should be replaced. Sometimes sugary substances or food residue can lead to button jamming. Try and keep liquids and food products away from the switch.
David Gedeon
crwdns2935283:009/17/15crwdne2935283:0
806 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-1, Baechle Fall 2015 crwdns2935289:0IUPUI, Team 1-1, Baechle Fall 2015crwdne2935289:0
IUPUI-BAECHLE-F15S1G1
crwdns2959996:0crwdne2959996:0 4,889
