Blank screen
Your screen appears blank and you don't know what to do.
Hold power switch on
It may be possible your phone is not powered on.
Drained or dead battery
If the phone does not turn on, the battery may be dead. Try plugging it into your charger. If that doesn't work, then you need to purchase a new battery pack. If so, follow our guide to replace the battery.
Hard reset
Before performing a hard reset, make sure you have backed up all your data. ALL DATA WILL BE ERASED. Hold the comm button and voice manager for 5 seconds. Then, using the stylus, press the reset button.
Bad display
Your display may be broken. In this case, you may need to replace it by following our guide to replace the display.
Bad motherboard
If none of the above troubleshooting tips fix your problem, most likely the motherboard needs to be replaced. To replace the motherboard, please follow our guide on replacing the motherboard.
Malfunctioning Camera
The camera doesn't display anything when its turned on.
Replace the Camera
Your camera may be broken. In this case, you may need to follow our guide on replacing the camera.
No Sound
There is no sound coming from my phone.
Replace the speakers
The speakers might be broken. If this is the case, a speaker replacement might be necessary. To do this, follow our speaker removal guide.
Stylus not working
The phone does not respond to the stylus.
Turn the phone off and back on
This is just powering the phone off and then back on, not to be confused with a hard reset.
Screen cable might be disconnected from the motherboard
This is a more complicated fix. You will need to follow our repair guide on replacing the motherboard.
Battery dies extremely fast
Your phone dies in the first couple hours of use.
Fully charge the battery
After phone completely dies, let it charge overnight or 8+ hours. If phone still has same symptom, you will need to replace the battery.
Replace the battery
If the phone still dies faster than normal, you should replace the battery.
Taylor Stone
crwdns2935283:010/06/11crwdne2935283:0
45 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-28, Maness Fall 2011 crwdns2935289:0Cal Poly, Team 20-28, Maness Fall 2011crwdne2935289:0
CPSU-MANESS-F11S20G28
crwdns2935297:084crwdne2935297:0
crwdns2959996:0crwdne2959996:0 980
