crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device does not turn on
The device does not power up when the power button is pressed.
Battery is out of charge
The battery needs to be charged. Plugin the adapter and charge the device.
DC charging port is defective
If the adapter is confirmed to work, but the device has run out of charge and will not charge, the DC charging port is defective. View this guide on how to replace the DC charging port.
Motherboard is defective
The motherboard is no longer functioning if the device does not turn on while plugged in. View this guide on how to replace the motherboard.
Adapter is defective
If there is no charging light on the device while plugged in, the charging adapter no longer works. Buy a replacement adapter.
Device turns on but does not charge
The battery of the Chromebook 11 G5 does not charge when the adapter is plugged into the device.
If the adapter is confirmed to work but the device still does not charge, the DC charging port is defective. View this guide on how to replace the DC charging port.
Battery is defective
The battery is no longer holding a charge. View this guide on how to replace the battery.
Device turns on but displays a black screen
The device displays signs of being powered on, such as the power light, and the ability to connect to a second display and use the device, but the device’s screen does not display any image.
The screen is defective
The screen is no longer functioning and needs to be replaced. View this guide on how to replace the screen
Screen displays streaking lines or distorted image
The screen has lines, patterns, or black spots on the display distorting the image.
Connect the device to an external monitor. If the image is still distorted on the alternate screen, the motherboard is no longer functioning. View this guide on how to replace the motherboard.
The screen is no longer functioning and needs to be replaced. View this guide on how to replace the screen.
Some keys do not respond to key-presses
Keys do not respond to physical input.
Keys are dirty
Keys may become unresponsive when dirty as they will not depress for input and require cleaning in order to function again. View this guide on how to remove dirty keys. Once removed, apply isopropyl alcohol using a paper towel or cotton swab to clean the key. Refer back to the guide for instruction to snap the key into place after it has been cleaned.
Keys are physically broken
If a key is physically broken, purchase a replacement key. View this guide for instructions on how to remove the broken key and replace it with the new key.
Keyboard assembly is defective
If the keys are not dirty or physically broken, the entire keyboard assembly is defective. View this guide on how to replace the keyboard assembly.
It is also possible that the cable was not properly seated in the connector; unplug it and make sure that nothing is blocking the connection in any way, then plug it in and test.
Device has wireless connectivity issues
The device drops connections on occasion or cannot connect to Wi-Fi at all.
The connection is out of range
Ensure the device is in range of the Wi-Fi router. The Wi-Fi signal may be disrupted if it is traveling through dense surfaces, such as brick or concrete walls. The signal may also face interference by the radio frequencies other nearby electronic devices emit, which can either slow down or completely drop a connection. Shift the device, router, or both to a new location within range of each other.
The Wi-Fi card is defective
If the device is in range of a Wi-Fi router but cannot find wireless connections, the Wi-Fi card is defective.
Kunal Chopra
crwdns2935283:001/14/20crwdne2935283:0
474 crwdns2915208:0crwdne2915208:0
York University, Team S1-G3, Woodhouse Winter 2020 crwdns2935289:0York University, Team S1-G3, Woodhouse Winter 2020crwdne2935289:0
YORK-WOODHOUSE-W20S1G3
One thing ive noticed is it will turn on for a few minutes, and then shut off. Why is this?
Addi Williams - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 39
crwdns2959996:0crwdne2959996:0 1,602
