Is your dryer not drying? Is it not heating up to its job, and has no warmth? You start it and come back later to check and find your dryer running dutifully with wet clothes still inside. Maybe a little bit more dry, but not dry enough. Maybe you come back and it has finished its cycle but the clothes are still wet. This is the place to walk through the possible causes, so you can understand what's going on and fix it.
For a great explanation on thermostats and thermal fuses, jump to this appendix.
Gas Supply Turned Off
Make sure the gas to your dryer is turned on.
- On the gas supply pipe to your dryer, there will be a small valve that controls the gas.
- Make sure the handle lines up with the pipe (on), and is not turned so it is 90 degrees to the pipe (off).
Ignition System Failure
Your gas dryer relies on a multi-step chain of events to ignite the gas and also to make sure that the gas doesn't get out when it shouldn't and ignite a fire in your home. To do this, the gas valve on your machine is really two valves in one. One valve will only allow gas to flow to the second valve if the machine is turned on and has power and the controls are set to require heat. The second valve will only allow gas to flow to the burner if the conditions are proper for the gas to be ignited.
- Your gas is usually lit by an igniter, a device that glows brightly when energized and gets hot enough to ignite the gas.
- A device called a flame or radiant sensor monitors this igniter and causes the gas to flow when the igniter is hot enough. It will allow the gas to continue to flow as long as the gas is burning properly.
- The solenoid coils on the gas valve can wear out over time so that they won't open the gas valve when they should. A failing hold coil can also provide a short circuit around the igniter, such that the thermal fuse blows from overcurrent.
You can check to see if this process is happening by watching the gas burner through a small observation port in the front panel of your dryer. Just pry off the small cover with a screwdriver. Some dryers won't have this port, but if you remove the top of the unit you can still see. Others will have a kick panel that can be removed. Be careful if you have to remove some of the cabinet (case) because of moving parts and possible shock hazards.
- Set the dryer to a setting that will require heat and start it.
- Make sure the setting you use requires heat and is not a cool-down time, which can be the last part of some cycles.
- It is best to test on a high heat setting and use a timed cycle.
- Watch the gas burner and see if the igniter glows.
- If there is no glow at all, you will need to check the igniter itself, along with the thermal fuse (see below).
- Unplug the dryer and open the cabinet.
- The Igniter should show about 80-400 ohms. (One extremely common 120VAC igniter measures ~72 ohms, which yields 200 watts.)
- if it is showing more resistance or no continuity at all it's bad; replace it.
- You can check the thermal fuse for simple continuity. If none, replace it.
- If the thermal fuse blows without the dryer heating, there is a short circuit (the wiring, igniter or the gas valve 'hold' solenoid coil).
- If the igniter glows and stays on for a long time (five minutes), and no flame starts, the problem is the flame (or radiant) sensor.
- If the igniter glows and stays on for a shorter time (up to two minutes) and then goes out with no flame igniting, the problem is the gas valve coils. Unplug the dryer, and test them for proper resistance (500-1500 ohms). (The 2-prong main coil might measure ~1500 ohms; the 3-prong coil might measure ~650 ohms [assist coil] and ~1600 ohms [hold coil].) Replace them if they show no continuity. Here's a good video to help you check them. However, proper resistance readings on a meter don't guarantee that they're not failing at the voltages and temperatures of actual use; if in doubt replace them. The insulation on magnet wire is thin and does fail with time.
Thermal Fuse Blown
Because the thermal fuse is a relatively frequent culprit, we start with this check. It can be a sign of other problems, so follow all the checks and don't just stop with replacing the thermal fuse if it is blown.
- Make sure the thermal fuse (TF) isn't blown. Check it for continuity.
- If it shows continuity, go on to Thermal Cutoff Blown, below.
- If there's none, it has blown. Replace it.
- If it has blown, the dryer may still spin, but won't heat. In other circumstances the dryer won't run at all. Replace the thermal fuse and....
- If TF is blown, make sure to check that your exhaust ducts are not clogged with lint.
- If TF is blown, also check your blower wheel as well for lint buildup or stray clothing, like a sock, which will impede airflow and cause this sort of overheating.
- More details on properly checking dryer airflow and ducts can be found on our Dryer Maintenance page
- If the TF is blown, check the Thermal Cutoff (below) as well.
- If the TF is blown, it is a good idea to just replace the Hi-Limit thermostat as well, since intermittent failures in the Hi-Limit can cause blown thermal fuses.
- If the TF is blown and after replacement blows immediately as soon as the dryer attempts to heat, there is likely a short circuit. If the TF is blowing from excess current (see Other Resources, below), there's a short circuit somewhere after the TF and around the igniter / flame sensor / gas valve hold coil.
## Note that the hold coil can fail at 120VAC, even with a normal (~1600 ohm) resistance at the low voltage used by an ohmmeter. So a short in that coil (which stays energized once the valve is opened) can blow the thermal fuse when that coil is energized
Thermal Cutoff Tripped
The thermal cutoff, if blown or tripped can also cause the dryer to not heat.
- Occasionally these will have a reset button on them, but most of the time they are like the TF a one-shot device.
- It will be located near the heat source. Test for continuity, if it checks, it's good. If no continuity, replace it, and like the thermal fuse, check for other problems with airflow.
Hi-Limit Thermostat Open
If the ducts are clear, it's a good idea to replace the Hi-Limit thermostat.
- When the Hi-Limit fails and sticks on because of a problem, the thermal fuse will blow (it's very reliable).
- Since this Hi-Limit issue could be intermittent, and the part is relatively inexpensive, replace it along with the thermal fuse.
- Check it for continuity, if it has none, replace it.
- If the Thermal Fuse or Thermal Cutoff was blown replace the Hi-Limit as well.
Faulty Cycling Thermostat
The cycling thermostat can stick open, causing the dryer to think it is hot enough, and not supply heat. Disconnect it from the wiring in the dryer and test for continuity (at room temperature). If no continuity, replace it.
Centrifugal Switch Failure
A less common failure is the centrifugal switch on the motor.
- This switch closes to maintain contact between the motor and power source, and also completes the circuit for the gas control system.
- Failure of this switch will keep power from the gas valve, which will ultimately prevent heat from reaching your clothes.
- The switch contacts can be replaced independently.
- Test the switch for continuity.
- You will need to determine which contacts are allowing current to flow through the gas valve.
- Disconnect one terminal and then check the switch for continuity. if none, the switch needs to be replaced (or possibly cleaned, but replacing is more sure) Here's a good video that shows how.
- If the switch operating mechanism on the motor shaft has gone bad, you will have to replace the entire motor. In this case, the dryer motor probably won't be running right either.
Timer Assembly Failure
Another less common failure is the timer assembly; the contacts which control the heat source may have failed. If your timer assembly has failed, you'll have to replace it, but timers can be expensive and are commonly misdiagnosed. Use a multimeter to check for voltage at the heating circuit and motor circuit before replacing the timer assembly.
Gas Valve Relay / Control Board Failure
When all else fails, you should check the Gas Valve relay on the control board if you can locate it and if it is replaceable. You can trace the wiring from the gas valve back to the control board and note if it is connected to a device on the control board that is usually a small rectangular component. the terminals are frequently on the device itself. Check to see if the device can be removed from the control board. If so you can try changing it out.
If that isn't possible or doesn't fix things, you can replace the control board.
Related Pages
Other Resources
Here is a video on Gas Dryer Troubleshooting
Here is some detailed information about Thermal Fuse issues
- The TF usually has a normal resistance of about +/-0.05 ohms, low enough that a 10A current yields about 5. watts, which noticeably warms it, but not enough that it will blow in open air.
- Normal current in the 120VAC igniter circuit shouldn't exceed a couple of amps (about 1.15 watts in the fuse). However, 13.7A or more yields 10W+, and it's probably intended to blow near that (before a 15A circuit breaker).
# Ideally, one would 'hipot' the solenoid coils (checking for excess current at the design voltage). On the other hand, if the coils are more than a few years old, buy a pair online for as little as $10-15 and replace them while you have access to the igniter area -- intermittent failures (gas valve doesn't open or stay open; thermal fuse keeps blowing) can be hard to debug.
A Few Words About Thermostats and Fuses
Dryers are intended to get hot, but not too hot. Because of this they have multiple safety and control systems built in. The components below are the ones you will hear about and check most frequently.
- Operating or cycling thermostat - This is the first line of control for the temperature of the dryer. It turns the heat source on and off.
- Hi-Limit Thermostat - This shuts off the heat in the event that the operating thermostat fails, or some other condition occurs, and the dryer is overheating. Other things like restricted airflow can cause this to operate as well. It is located near the heat source.
- Thermal Cutoff - An alternate version of the Thermal Fuse. In some cases, it controls the blower motor, in others the dryer's heat source. It may be in tandem with the Thermal Fuse. A few are resettable. They're usually located near the heat source.
- Thermal Fuse - The last line of defense. When it blows it means either the machine stops completely, or it will run with NO heat. It backs up the Hi-Limit Thermostat and Thermal Cutoff. A relatively frequent cause, they can just fail with age as well as from excessive heat or excessive current. They are usually located on the exhaust, downstream of the blower.
Here's a picture of a thermal fuse (red arrow and box):
Image from howtofixit.net
- Thermistors - These take the place of the bi-metallic thermostats. Instead of being an on-off switch, they are a heat-operated variable resistor. Frequently, dryers with electronic controls will employ one or more thermistors in place of thermostats. To test them, you need a service manual for your dryer, as there will be specific resistance readings to verify.
Draai wel maar wordt niet warm
Carlos Lima - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
De droger draat maar wordt niet warm wat is het probleem
Mooki - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Zoek de problemen
