crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Fitbit Not Connecting To Mobile Device
Smartwatch is not connecting to Bluetooth device, in this case most likely your smartphone. Blaze is attempting to connect to mobile device but results in a failed connection.
Bluetooth Disabled/Damaged On Smartphone
Before connecting your smartwatch to your smartphone double check that Bluetooth setting is "ON". Go to phone settings, Bluetooth menu, enable/scan for devices. Select Blaze from available devices to connect.
Note: Some smartphones disable their Bluetooth in order to save battery life or after a shutdown. Enable Bluetooth at all times to prevent disconnection from Blaze. If it fails to connect then perform a connection test with a different device to test phone's Bluetooth functionality.
Bluetooth Disabled On Blaze
Make sure that the initial configuration and setup of the smartwatch has been completed. Go to settings and double check that the Bluetooth setting is set "ON".
Faulty Bluetooth Adapter
Before taking further action perform a restart on your smartwatch. Find the Back and Select buttons on your Fitbit Blaze (left and bottom right). Press and hold the Back and Select buttons for about 10 seconds, until you see the Fitbit logo appear. Release the buttons.
Note: If Bluetooth connectivity issues continue, please refer to our motherboard replacement guide here Motherboard Replacement
Random Vibrations
Vibrations occurring randomly without notifications of a call, text and other functions.
Tracker Not Syncing
Restart your smartwatch. Find the Back and Select buttons on your Fitbit Blaze (left and bottom right). Press and hold the Back and Select buttons for about 10 seconds, until you see the Fitbit logo appear. Release the buttons.
Note : Resetting the tracker may fix the following problems:
  • Tracker is not responding to button presses, taps, or swipes.
  • Tracker is charged but doesn't turn on.
  • Tracker isn't tracking your steps or other stats.
Vibration Motor
The vibration motor is damaged and needs replacement. Please follow our replacement guide here Vibration Motor Replacement
Screen Unresponsive
Experiencing unresponsive screen symptoms, these can include lag between swipes, screen not responding to button functions, screen frozen on logo startup.
Defective Boot-up
The software may have a startup issue in which a system restart may fix the unresponsive screen. Perform a restart on your smartwatch. Find the Back and Select buttons on your Fitbit Blaze (left and bottom right). Press and hold the Back and Select buttons for about 10 seconds, until you see the Fitbit logo appear. Release the buttons.
System Update
Your tracker may be using outdated firmware, perform a system update to get the latest issue-free system version from Fitbit. In order to update your firmware from the Fitbit app, verify if the latest firmware version is currently installed on your device. Make sure your device is fully charged to prevent issues during installation. Tap or click Select Account. Then tap or click the Update Tracker button. This option will only be available if Fitbit has released a new update. Follow the on-screen prompts and keep your tracker close to your smartphone during the update to prevent disconnection. Note: If update is slow, do not disconnect your tracker from your account. Tracker will restart when the latest firmware is installed after update.
Damaged Screen
If a system restart did not fix the unresponsive screen, the screen may need to be replaced.
Poor Battery Life
Device will not charge properly or battery is suddenly draining quickly.
Cleaning contacts
Check the contacts on the tracker where the charger plugs in. Over time, dirt can collect on the contacts and prevent a proper charge. Use a cotton swab soaked in rubbing alcohol to lightly dab the contacts clean.
Note: The clean contacts should appear gold in color.
Using a different USB port
Try plugging your charger into a different USB port, or a new outlet altogether. One of those may be defective and is preventing your device from charging.
Disabling features
Disabling some unused features on your device will help conserve battery life. These settings can be switched on and off in the settings menu on your device.
  • Heart Rate data collection
  • Lower brightness
  • All-Day sync
  • Quick View
  • Notifications
Bad Battery
If these methods do not improve your battery life, your battery may need to be replaced. Please follow our replacement guide here Battery Replacement
Heart Beat Monitor Not Working
There are two different ways your heart beat monitor will fail. The first way is that the heart beat monitor stops giving a reading and the second is that the lights in the back of the smartwatch stop working.
Heart Beat Monitor Stopped Giving a Reading
If the heart beat monitor is not tracking your heart beats, Go to the settings option and go to Heart Rate Tracking. Turn the setting on to AUTO, Make sure the band is tight around wrist. If it is not tight enough the heart rate monitor can not read your heart rate. Try moving the band around your hand with higher or lower variations in the arm. If it is still not working try switching the setting to ON. This will enable the green light on the back of the tracker even when you're not wearing it. Note: If it is still not working, restart your tracker using our How Do I Restart My Tracker above.
Green Lights Not Working
If the lights are not working, check your profile settings to make sure if heart rate setting is set to auto or on.
Faulty Heart Rate Monitor
If none of the above fixes the issue then you have a faulty heart rate monitor. Contact Fitbit customer support in order to request a replacement.
Adrian Borrego
crwdns2935283:002/20/17crwdne2935283:0
2.242 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S3-G3, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team S3-G3, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S3G3
crwdns2944067:089crwdne2944067:0
this afternoon I looked down at my fitbit and it was blinking back and forth rapidly. Just shut it down in between the blinks now seems to be ok...... what happened?
Has this been an issue for others?
dawn.donovan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yes, My fitbit started acting in similar manner since yesterday. Dunno what to do.
Vishal Rao - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My doing the same thing. Vibrating rapidly for no reason and I can’t stop it.
theleespot - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This is the problem that brought me here.
Holly & Nathaniel Olsen - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 142
crwdns2959996:0crwdne2959996:0 137,894
