crwdns2959928:0crwdne2959928:0 ↓This guide will help you step by step in replacing your damaged vibrating motor. Note soldering will be required, please follow this wonderful guide for helpful tips. Soldering Connectors
Locate the front LCD screen on your device.
Push the screen out through the back of the metal ring enclosure.
Locate the metal pin behind the wristband located on the edge of metal ring.
Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
Remove wristband.
Locate the pin behind the second wristband located on the edge of metal ring.
Insert the pointed end of the metal spudger into the pin hold and push it into opposite direction.
Remove wristband.
Place device screen face down and locate the four screws attaching the back cover.
Use a T3 torx head or T3 torx screwdriver to remove the four screws.
Grab the back, lift and open like a book to expose the motherboard. Locate the ribbon connector on the left.
Use a plastic spudger tool on the ribbon connected from the heart rate monitor to the motherboard.
Insert and lift the plastic opening tool to release the ribbon.
Separate the back and set aside, locate the three screws attaching the motherboard.
Use a PH000 head or a PH000 screwdriver to remove the three screws.
Use a plastic spudger tool on the ribbons connected to the motherboard.
Insert the tool under the ribbon and lift to release the connection.
Lift and push the motherboard to the side to uncover the 167mAh battery.
Use a plastic spudger tool to pry out the battery from its adhesive plastic underneath.
Lift up and pull downward to remove battery. Switch to the top portion of the battery and push downward to pry out battery.
Flip the motherboard back to the front to locate the metal pins from the vibration motor soldered to the board.
Desolder the connection to remove the motor component.
Follow this guide on how to solder and desolder connectors Soldering Guide
anyone got a part number or a description of the motor that gets replaced. looking to do this and fix. thanks
Ben - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
And how many destroyed “FitBit Blaze” are we going to see now?
tjhbob - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
what kind of motor can you replace this with?
dbick - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Any idea what is the value of the C3 capacitor?
P J - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
