crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Emerson EM744 Will Not Turn On
Emerson EM744 screen won't light up, device won't boot up.
Bad Power Supply
Ensure that the Emerson EM744 Tablet’s battery is not dead, and can hold a charge. Attempt to charge your device and try to turn it on after a few moments of charging. If the device wont turn on due to a bad power supply, you can use this guide to replace the battery.
Bad Power Button
If Emerson EM744 wont respond to the power button, there may be a connection problem between the power button and the mother board. If this is the issue, you may need to replace it.
Screen brightness is not turned up
Attempt to turn up the brightness. It might be able to see the brightness meter by going into a dark room and looking at your tablet.
Emerson EM744 Audio isn’t Working
Sound is distorted or isn’t working at all.
Speakers have sustained damage
When sounds are distorted (popping, scratching, muffled, etc.) or have stopped working, the speaker in the tablet may have become damaged and is unable to work. If you hear any of these distortions the speaker may be damaged or broken. Use this guide to replace the speaker in the Emerson EM744.
Emerson EM744 Won’t Charge
Emerson EM744 won't respond to charger.
Bad Power Supply
Ensure that the Emerson EM744 Tablet’s battery is not dead, and can hold a charge. Attempt to charge your device and try to turn it on after a few moments of charging. If the device wont turn on due to a bad power supply, you may need to replace the battery.
Emerson EM744 is Not Plugged In
Ensure that the device is plugged into the electrical outlet or USB port, correctly.
To avoid charging issues, use official chargers with the tablet.
Mother Board is damaged by charging port
The mother board is slightly melted where it connects to the charging port. This will make charging impossible as there in no longer a connection to the charger. Use this guide to swap out the mother board.
Emerson EM744 Cameras Won't Function
The Emerson EM744 cameras won't feed image or display proper image.
Emerson EM744 Cameras are Damaged
Emerson EM744 cameras may be damaged. To replace the cameras, follow this guide.
The camera is dirty
Try wiping off the camera lens. This could be the cause of the blurry pictures.
Can't Connect to Wi-Fi
The device is unable to find or connect to any wireless networks.
Reset router
You may not be able to connect to the Wi-Fi because your wireless router is not working properly. Try resetting your wireless router.
Invalid Settings
The correct Wi-Fi settings may have been corrupted or accidentally changed. Reset to the default network settings, choose the desired network you wish to connect with, and enter the wireless network password.
Malfunctioning Wi-Fi Antenna
If none of these options have corrected the issue, please refer to our replacement guide for the Wi-Fi Antenna inside the device.
Akinola
crwdns2935283:009/20/16crwdne2935283:0
177 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-5, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 2-5, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S2G5
crwdns2944067:06crwdne2944067:0
Where do I find default settings in my Emerson tablet to correct my Wi-Fi setting
Brandon - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Mine will power on and it stay on for a couple minutes and then the screen will go black. My battery is charged and it will still do that
Bryce Moubray - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Mine is doing the same thing as Bryce's. Any suggestions
Carol Haynes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have been locked out of my tablet bc I forgot the pin number
Elisa Johnson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2959996:0crwdne2959996:0 3,064
