crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Volume (Sound) Is Not Playing From the Device
The projector is not making any sounds.
Device is Muted
Ensure that the projector is not muted by checking the volume buttons on the device.
Headphones are Plugged into the Device
If the device is connected to an earphone, the audio is being transmitted to that rather than the speakers.
HDMI Cable is Connected to the Wrong Port
After connecting the device, unplug the wires and plug them back in after a few seconds. Also check that the device used for connection has working audio outputs and the right settings.
  • Change the audio format and try it again
  • Change the port to transmit audio signal
Faulty Speaker
If the speaker has blown out or is faulty, use this speaker replacement guide.
Blurred Images
The image is low quality or blurry.
Device Adjustment
Light Levels
If the environment is too bright, the image will not be as detailed. Turn off the lights and cover the windows.
Broken Lamp
If the projector lamp is broken, follow this guide to replace it.
Image Will Not Display
There is no or a dim image output.
Lens is Covered or Broken
HDMI Port
The HDMI port is connected to another device, but there is no output.
  • See if you have selected the correct Input Source. The source should match the HDMI where you connected the HDMI cable.
  • Check whether the HDMI cable supports HDCP or not.
  • Make sure the HDMI cable is not broken. You can try to change the HDMI cable and try again.
Lens is Broken
If the lens is broken or faulty, follow this guide to replace the lens.
Overheating
The device is getting too hot.
Vent Blockage
Check the vents on the back of the device and make sure nothing is obstructing their airflow. If the bottom of the device is hot, this is fine. The DR.J Professional HI-04 has good heat dissipation.
Device Run Time
Do not leave the device on for over four hours or when it gets hot. Turn it off until it cools down and then resume usage.
Projector Location
Put the device into a cool and well-ventilated space to avoid dust building up. Avoid warmer rooms as this could lead to overheating. There should also be no heating device near the device.
Broken Fan
Look at the fans and see if they are spinning when the device is turned on. The fan being loud is not broken. The HI-04 is a mini projector and needs to cool down quickly. Follow this guide to replace the fan of your project.
Device Does Not Power On
The projector will not respond or turn on.
Power Cord Plug
Ensure that the power cord is not loose and fully plugged into the port.
Main Power Switch
Check to see if the main power switch is flicked to “on.”
Faulty Fan
Feel the projector to see if the temperature is overheating. The projector has a safety feature that does not allow it to be turned on past certain temperatures so this should not be a factor. If the fan needs to be replaced, follow this guide.
Projector Lamp
Ensure that the projector lamp is not past its life expectancy. If it is, you may need to replace the lamp.
Faulty Motherboard
If you have checked the other components and the projector still won't turn on, it is likely the motherboard. Consider replacing the motherboard with this replacement guide.
Baron Dutra
crwdns2935283:011/01/23crwdne2935283:0
825 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-5, Petersen Fall 2023 crwdns2935289:0UMass Dartmouth, Team 1-5, Petersen Fall 2023crwdne2935289:0
UMASSD-PETERSEN-F23S1G5
Hi, I have managed to snap the adjustment piece that adjusts the projector to be level. What would be the best way about either setting it into one place permanently or ideally repairing it?
john nolan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 98
crwdns2942667:0crwdne2942667:0 3,590
