crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Player won't turn on
The device does not react to any user input, and stays dark.
Hold button is switched
Make sure the hold/power switch is in the middle position.
Device is not charged
The battery might be dead; try charging it for at least 30 minutes.
Battery dead
If the battery does not charge, the battery might not be working, and should be replaced.
Shorted circuitry
If replacing the battery with one that is known to work does not fix the problem, the main motherboard may be damaged, and should be replaced.
Malfunctioning Display
The screen shows one or more distinct dark or discolored spots.
Dead pixels
If your device has small squares that are dark while the rest of the display is fine, you may have dead pixels. The simplest fix for this is replacing the LCD display.
Broken Screen or Case
A bent, cracked, or shattered screen or case can lead to further problems if not dealt with
Broken Screen
A broken screen is a fairly simple replacement.
Input Not Responding
The device turns on, but some or all of the buttons on the keypad don't seem to do anything
One or more buttons don't work
It might help to remove the case and re-seat the rubber keypad mat on the circuit board it sits on, or remove debris that might have accumulated underneat it.
All buttons don't work
You may need to check the connection between the keypad and the motherboard, or simply replace the whole assembly.
No Sound
Whether the speaker or the headphone jack, the device fails to produce sound.
Broken Speaker
If the headphone jack still works but the built-in speaker does not, the speaker should be replaced.
Malfunctioning sound card
If either sound output is not working, the simplest fix is to replace the motherboard, which both components are soldered directly on to.
Ryan Ingram
crwdns2935283:001/13/15crwdne2935283:0
4 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team 1-5, Sullivan Winter 2015 crwdns2935289:0USF Tampa, Team 1-5, Sullivan Winter 2015crwdne2935289:0
USFT-SULLIVAN-W15S1G5
I dropped my X-Fi and now the screen is blank. It’s lit up, but it’s bright white. The player performs perfectly except for the screen being bright white. Any suggestions? I love this little player and hate to give up on it (though it plays fine, it’s hard to navigate without the display working).
Jo Booms - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My zen x-fi won't power up and show an amber light on the power light then it stay red but the screen also stays black.
Help please
Adam Puddick - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 41
crwdns2959996:0crwdne2959996:0 3,470
