crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Keyboard Does Not Turn On When Power Button is Pressed
Keyboard is completely unresponsive
AC Adapter is not Plugged into the Keyboard Power Port
The AC adapter’s circular end should be plugged into the power port in the back of the keyboard. If the cable is loose, push the circular end carefully into the power port.
AC Adapter is not Plugged into an Electrical Outlet
If the AC adapter is loose, plug the AC adapter into the electrical outlet. If the AC adapter is not loose, test using another electrical outlet.
Power Port of the Keyboard May Be Damaged
If the AC adapter is plugged into both the electrical outlet and the power port, the power port on the keyboard may be damaged.
No Sound Heard Through Headphones
The headphones do not play sound when keys are played
Broken Headphones
Test headphones using a different device. If no sound is heard through the headphones, replace headphones
Jammed Headphone Jack
Shine a light in the headphone jack to check if there is something lodged. If there is something stuck, remove the object with insulated tweezers.
Headphones are not Plugged into the Audio Port
If the headphones are plugged in but you are still unable to hear sound, the headphone jack may be damaged and need replacing.
Keys Sticking
The piano keys are stuck up/down
Keys are dirty
When the keys are dirty, sounds may not be heard when the keys are played. You will need to clean them thoroughly.
Keys are jammed
Check spaces between keys for any small object preventing upward motion. If there is no visible obstruction, there may be a small object inside of the keyboard causing this jam. See our Key Replacement guide to check under the keys.
No Sound Is Coming From Key(s)
Individual keys
Single keys do not produce sound but neighboring keys function properly
Key Contacts
Key contacts are dirty. Cleaning will require opening up the keyboard; see the Key Replacement for further instructions.
Speakers
Speakers are not receiving power, reference the Speaker Replacement Guide.
All keys
Sound is not produced when any keys are played
Volume
Check if the volume knob is turned to an audible level. While holding a key down, turn the volume knob clockwise and listen for sound.
Broken Headphones
If the headphones do not work with any other devices, they may need to be replaced.
There may be something lodged in the headphone jack. If so, remove the object with insulated tweezers
Speakers
If the volume, headphone jack, and headphones all work, the speakers may be broken. Replace the speakers using the Speaker Replacement guide.
Buttons Are Not Responding
Option buttons do not respond when pressed
Buttons are not receiving power
A loose wire or jammed object may be preventing the buttons from contacting the circuit board. See the Button Panel Replacement guide.
Pitch Bend Is Not Responding
The pitch is not changing when the pitch bend is adjusted.
Pitch Bend of the Keyboard May Be Damaged
If the pitch bend is not responding, reference our Pitch Bend Replacement Guide.
Gavin Chao
crwdns2935283:010/02/17crwdne2935283:0
191 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S4-G2, Livingston Fall 2017 crwdns2935289:0Cal Poly, Team S4-G2, Livingston Fall 2017crwdne2935289:0
CPSU-LIVINGSTON-F17S4G2
crwdns2944067:08crwdne2944067:0
Was playing & keyboard cut out.power off ..so turned back on & won't stay on .it lights up & stays on while finger still on power button but soon as i take of it shuts off .while this happens no sound even pressing keys .. any thoughts ?
troyadbailey - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Cdp 230r light in the window comes on when the button is pushed but no sound from the keys take your finger off and the light goes off
Brett Irving - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I had it sitting away in my cupboard for no longer than 2 weeks, pulled it out to play today and won’t even turn on
Ashley - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
had sitting alone in computer room for 3 months and just powered on and everything lights up and looks fine, but no indication that keys are being pressed and no sound and none of the option buttons does anything.  There are not headphones plugged in.
Lynn Tober - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Casio CDP 235R will not produce any sound. The piano is reset to the factory settings per instructions in the manual. Still no sound. When the keys are pressed, the display shows the keys that were depressed. None of the special keys work either. The display is lit and reflect the knobs being used. There is no head phones used. The only two cords plugged in the back side were the same two cords that were there when there was sound. The two chords were the power cord and the cord to the sustain pedal.
This piano is not used very often - maybe 5 times a month. It had not had any problems until now. Can anyone shed any light to this lack of sound issue? Thank you in advance. Lyn Herbert
Lyn Herbert - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 74
crwdns2959996:0crwdne2959996:0 6,061
