crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Is your Anker Soundcore Motion Boom Plus unable to turn on when the power button is being pressed. Use this troubleshooting guide to help diagnose why.
Charging Cable Not Plugged in or Faulty
A faulty or loose charging cable can stop the device from charging. Ensure the cable is connected to both the device and the power source. If the device still does not charge, try using a different USB-C cable that meets the required 5V/3A specifications for Anker Soundcore Motion Boom Plus. The device port might have dust or debris inside. Clean it carefully to ensure a proper connection. If the previous solutions have not addressed the problem, you may need to replace the charging port. Please refer to the replacement guide for the Anker Motion Boom Plus charging port linked here.
Battery Failure
If the device does not hold charge despite using a functional charger, the internal battery may be failing. To ensure the battery is failing, charge the device for at least 30 minutes before turning it on. If it does not turn on and all the other solutions have been ruled out, Please refer to the replacement guide for the Anker Motion Boom Plus battery linked here.
Faulty Power Button
There is a possibility of a malfunctioning power button that is causing the device not to turn on even if the charging cable is not broken and the battery is working fine. If pressing the power button does not turn the device on, please refer to the replacement guide for the Anker Motion Boom Plus replacement guide for the button panel linked here
Hayley
crwdns2935283:003/26/25crwdne2935283:0
988 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-7, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 3-7, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S3G7
crwdns2935297:071crwdne2935297:0
crwdns2942667:0crwdne2942667:0 411
