crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device is Frozen or Will Not Power On
Cube does not show any sign of powering on.
Faulty Power Adapter or HDMI Cord
Make sure the TV is turned on and the channel is set to the same HDMI input screen that the Amazon Fire TV Cube is on. Unplug the power cord and plug it back in. If the light is not on and the adapter is plugged in, the adapter is faulty. Consider trying a different HDMI cord or a different power cord.
Incorrect Resolution
Push the Up and Rewind buttons located on your Fire TV Remote at the same time for five seconds. Your screen will then scroll through different resolutions, when you see the correct resolution, select “Use Current Resolution”.
Fire TV Cube Needs to Restart
Press and hold the Select and the Play/Pause buttons at the same time for five seconds. Or, select Settings > My Fire TV > Restart from the Fire TV menu.
Voice Command is Not Working
Alexa will not respond.
Bluetooth Devices or Background Noises are Interfering
Make sure the Fire TV Cube is at least one foot away from speakers. Move other Alexa devices out of the room, and speak clearly with no background noise. If there are other Alexa-enabled devices, on the Fire TV Cube, go to Settings > Alexa, and turn Favor this Device On.
Voice Command Needs Reset
To test voice command, press the action button on the Fire TV Cube or hold down the Voice button on the remote. If the Cube lights up after voice command test, but you do not hear a response, clearly say "Alexa, I cannot hear you." Fire TV Cube then responds to you through its speaker instead of the TV or audio device.
Audio is Distorted or Silent
You have trouble listening to sounds from your Amazon Fire TV Cube.
Volume is Muted
Make sure your TV Cube’s volume isn’t muted and adjust if needed.
A/V Receiver Connection Problems
If you use an A/V receiver, make sure that the Fire TV is connected correctly and the receiver is on. Disconnect the receiver and reconnect correctly if necessary.
Fire TV Menu Settings Incorrect
Review your Fire TV settings by selecting Settings > Display & Sounds > Audio on the Fire TV menu. Make sure the Dolby Digital Plus is OFF. Make any changes necessary and troubleshoot again.
HDMI Cord Connection Problems
If you have an HDMI cord connecting your Cube to your TV, make sure the cord is connected correctly, disconnect and then reconnect if needed. It may be necessary to use a different HDMI cable if yours is damaged or broken.
Still Unsuccessful?
If none of the above suggestions work, try replacing the Fire TV Cube speaker using this speaker replacement guide.
Remote Control is Not Connecting to Cube
You have trouble connecting the remote control to the Fire Cube.
Faulty Batteries
Make sure the batteries you put in the remote are working correctly by putting batteries in another device to see if they work. You may need to replace the old batteries with new batteries. Replace the batteries using this battery replacement guide.
Dead Batteries
Make sure the batteries you put in the remote are fully charged by putting the batteries in another device to see if they work. You may need to replace the old batteries with new batteries. Replace the batteries using this battery replacement guide.
Other Remotes or Bluetooth Devices are Interfering
If you have more than seven remotes and Bluetooth devices on, turn the ones you aren't using off. This will help the remote have a better time connecting to the Cube.
Remote is Not in Range
Make sure Fire TV Remote is 10 feet away from the Cube when trying to connect. Don't place the Cube in a closed off space such as a cabinet. Move the Cube away from the TV to limit interference.
Remote is Not Paired to Cube
Follow these instructions to reconnect your remote to the TV Cube:
1. Press and hold Home button for 10 seconds. Remote should take about a minute connect with Cube.
2. If step one does not work, unplug power adapter from the Fire TV Cube.
3. While the Fire TV Cube is off, reset the remote by pressing and holding the home button, back button, and the left side of the navigation ring all at the same time. Hold them for about 25 seconds.
4. Remove the batteries from the remote and plug the Cube back in. Make sure the home screen turns on.
5. Put the batteries back into the remote and wait about one minute.
6. If remote still doesn't connect, press and hold the home button for about 10 seconds.
Fire TV Cube Controls are Unresponsive
Control buttons on Cube are unresponsive and do not light up.
Restart the Fire TV Cube, disconnect the power cord from the back of the cube or the outlet, then plug it back in. To restart using the remote, press and hold the Select and Play/Pause buttons at the same time for five seconds. Or select Settings >My Fire TV >Restart from the Fire TV menu.
Faulty Power Cord or Adapter
Make sure you are using the power supply cord and adapter provided with the Fire TV Cube. Connect the power adapter into the power port located on the back of the Cube, then plug the cord into a power outlet. You may need to replace the adapter and/or cord in order to fix this issue.
Faulty HDMI Cable
Plug one end of the HDMI cable into the HDMI port on the back of the Fire TV Cube, then plug the other end into HDMI port on TV. If you are using an HDMI hub, first disconnect the Fire TV Cube from the hub and plug it directly into the TV. You may also try switching HDMI ports on the TV. If none of the work, consider trying a “1.3” or “1.4” High-Speed HDMI cable.
TV Cube Broken Button
Follow this Amazon Fire TV Cube button replacement guide to replace a broken or unresponsive button.
Justice Davis
crwdns2935283:009/27/18crwdne2935283:0
237 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team S1-G1, Johnson Fall 2018 crwdns2935289:0Linn Benton Community College, Team S1-G1, Johnson Fall 2018crwdne2935289:0
LBCC-JOHNSON-F18S1G1
crwdns2944067:0136crwdne2944067:0
Trying to figure out how I can just get sound coming out of the cube instead of my bose speakers…want to play xbox can listen to music on my fire cube at the same time
Michael - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Please I need help with my amazon TV fire cube. It come plays a tone flashes a blue light twice and that's it. Dosen’t finish booting, doesn't prompt for set up or even appear on my TV.
THANKS FOR ANY HELP I CAN GET
Casper
casper chidubem - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Please I need help with my amazon TV fire cube. It comes on and plays a tone and the lights keep going across on the fire TV box and that's it. Dosen’t finish booting, doesn't prompt for set up just shows fire TV on my TV screen with three dots flashing at the bottom right hand corner
alan hodgson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same problem here. Firecube flashes blue, then blue-green, then flashes green twice and appears to power itself off. (Doesn’t finish booting.)
Donnie Cameron - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
FIXED! Incredibly (given the symptoms), it turns out that my problem was the power supply. I used a power supply from one of my other devices (an Echo Dot) and my Fire TV Cube started working perfectly again. However, it lost all the settings, so I had to go through the setup again.
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 351
crwdns2959996:0crwdne2959996:0 190,837
