This guide will walk you through the step-by-step procedures to remove and replace the speaker in your Amazon Fire TV Cube. These steps are simple, however some require considerable force. To complete this replacement you will need a small screwdriver and opening tool.
Using a metal spudger, push down between the edge seals on the base and pry off the base.
Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
Our volume pauses every 11 minutes! Troubleshooting our Sono’s System…still doing it. Could this be our Fire Cube?
