crwdns2936621:0crwdne2936621:0
crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0iPad Pro 10.5"crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. iPad Pro 10.5" Teardown, iPad Pro 10.5" Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 10.5" Teardown, iPad Pro 10.5" Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You can relax now—this iPad is a professional. All kidding aside though, this thing boasts some impressive specs:
    • Fully laminated, 10.5", LED-backlit, Oxide TFT "True Tone" display with 2224 × 1668 resolution (264 ppi), featuring ProMotion Technology
    • 4th-generation 64-bit Apple A10X custom processor, with M10 motion coprocessor
    • 12 MP OIS rear camera with 4K video recording at 30 fps, and 7 MP FaceTime camera with 1080p video
    • Self-balancing, four-speaker audio
    • Touch ID sensor, 2 microphones, ambient light sensor, accelerometer, barometer, and 3-axis gyro
    • 802.11a/​b/​g/​n/​ac dual band MIMO Wi-Fi + Bluetooth 4.2
    • 64, 256, or 512 GB of on-board storage
  2. iPad Pro 10.5" Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Along with all-new performance specs and screen size, Apple launched a new model number, giving us a fresh A1701.
    • How much bigger is bigger? Yesteryear's iPad Pro 9.7" measured in at 9.4" x 6.6", while the new Pro is 9.8" x 6.8". (And at 0.24", they are both equally thick thin.)
    • In short: not much bigger.
    • That being said, the bezels have been significantly reduced. So, the new Pro won't feel bigger in your hands, but it will look bigger where it counts.
    • Other changes include: a microphone-hole migration, from beside the rear-facing camera to the selfie camera zone.
  3. iPad Pro 10.5" Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iOpener
    $24.99
    • Like most iPads, entry into this unit is guarded by strong adhesive—but the thinner bezel means it's easier than ever to accidentally jam a pick between the display and laminated glass.
    • Luckily, we're seasoned teardowners, well-equipped with the proper tools for the job.
    • Still, slicing blindly into a new iPad is always scary, since there's always the danger of cutting through a random display cable ...
    • ... except when there's not! Apple put the display cables right down the center, out of harm's way.
    • We've seen this arrangement in an iPad only once before, and it appears Apple finally managed to unify the Pro line around this somewhat more symmetrical design.
  4. iPad Pro 10.5" Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Right about now, Apple's earning a pat on the back for using Phillips screws over the display cable bracket—unlike those pesky tri-point screws we uncovered in the iPhone 7 (Plus).
    • They also connected the display cable near the Lightning port instead of dead center, making repairs slightly less awkward.
    • But it does look as though we'll have to remove another heavily glued-in logic board. Let's cross our fingers for battery pull tabs!
    • While planning our attack, we flip the switch on our X-Ray vision (courtesy of our friends at Creative Electron) to peek behind all those black boxes.
    Battery connector should be separated from its terminal with a plastic card or pick. Should be done first before unplugging the screen. I expect this from YouTube but not from ifixit!
    Jonathan Faulk - crwdns2934203:0crwdne2934203:0
    @fau1ker iFixit teardowns aren’t meant to be used as instructions (hence the large banner at the top of this page that says “this is not a repair guide.”) Teardowns are fast-paced, often destructive, and we purposely skip a lot of details. If you’re looking for the proper procedure, use a repair guide.
    Jeff Suovanen -
  5. iPad Pro 10.5" Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To the naked eye, this display doesn't look all that different from previous generations. And with a resolution of 264 ppi, it's not the first Retina display iPad.
    • All the same, 120 Hz is a blisteringly fast refresh rate for this many pixels, which is probably why it needs four (!) connecting cables. (Its ginormous older brother got by with just two.)
    • The slimmer bezel and True Tone tech also set this display apart—but we're here for the guts. After melting off a couple shields, we find:
    • Intersil ISL24882B TFT-LCD Vref generator/programmable gamma buffer (likely)
    • Parade Technologies DP825 timing controller (likely an upgraded version of Parade ICs we've spotted in previous iPad Pros)
    • Texas Instruments TPS565158 display power management
    • Texas Instruments TMP456 remote/local temperature sensor
    Which manufacturers is the Display? Not Samsung, not LG. A good question.
    Brian Wehrhahn - crwdns2934203:0crwdne2934203:0
    Will iPad Pro 10.5” display fit and work on iPad Air 3?
    mail2augus87 - crwdns2934203:0crwdne2934203:0
    What is the core component for True Tone tech’s operation.
    Dause Johnson - crwdns2934203:0crwdne2934203:0
  6. iPad Pro 10.5" Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In our Wi-Fi version of the 10.5" Pro, Apple left some mysterious plastic blocks where the LTE antennas might be found.
    • To add to the mystery, these weren't present in the Wi-Fi 12.9" iPad Pro...
    • We are speculating that it adds support to the display assembly, as opposed to being empty space as seen in earlier iPads.
    • Nothing much to see until we remove the large shield covering the logic board. Time to unzip it and see what we find.
    What is on the other side of the front-facing camera? (I assume that's the top there - but what are the "microphone holes" next to the audio jack doing at the *top*?) My guess is that the plastic block is not just support for the display, but to balance the weight.
    What are the regularly spaced "black bosses" (the engineering sense..) behind the spacer? They look like rubber shock absorbers for the screen. To reduce errant motion if the thing is being flung hither and thither when used when hunting flying Pokemon? (Courtesy of ARKit of course)
    And - ahoy! Are those normal **Phillips** screws I see there? Inconceivable!
    jimwitte - crwdns2934203:0crwdne2934203:0
    Remember, there are four speakers—two on top, and two on the bottom. ;) That's what the row of holes is for (you can see them in Step 8). The plastic blocks are hollow and weigh virtually nothing, so I tend to favor the "display support" theory.
    Jeff Suovanen -
    The LTE version that I’m holding open right now does not have those “spacers”, it actually holds the WiFi/LTE antenna in there. iPad Pro 10.5 (a1709) (2007).
    I would like to get some feedback/confirmation on my statement.
    Dante Estus - crwdns2934203:0crwdne2934203:0
    So has Apple FINALLY put a DAC in this tablet? I generally use my Astell & Kern PDA for listening to music. I have the Tidal app and I noticed that my iPad Pro 10” sounded like it has a DAC onboard , but I thought maybe it was just because I was tilting it or something. Looked at getting a iFi headphone amp as it’s suppose to playback Master Quality Audio from Tidal. I have a home setup that allows me to play MQA disc I purchased from Japan and some are really good, others are not as good as the Platinum SHM (24Bit/192kHz). Queen is a good example of the MQA Disc sounding less than stellar compared to the Platinum SHM version. I don’t use my iPhone for much but a phone. I might look into an iFi device now, for Tidal streaming.
    James - crwdns2934203:0crwdne2934203:0
    Hi, where do I find this electromagnetic cover for the motherboard?
    Thanks
    kris - crwdns2934203:0crwdne2934203:0
  7. iPad Pro 10.5" Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • As we delve deeper into the shallow device, we realize we haven't spotted any internal cabling yet.
    • We find this 3.5 mm headphone jack and speaker driver right where we expect ...
    • ... but instead of routing their ribbon cables over the top of the speaker resonance chamber like in their 12.9" counterparts, Apple has tucked the cables rather inconveniently underneath—that is, sandwiched between the speaker and rear case.
    • Lifting up a strip of padded conductive tape, we find screws! Last time we had a sad time removing Pro speakers, so screws are a good sign.
    • Psych—those screws didn't save us from fighting through nasty adhesive to remove the speakers.
  8. iPad Pro 10.5" Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Sure enough, allllllll the connecting cables are hiding out under this overturned rock speaker chamber.
    • At least the speaker chamber itself comes out intact, with the driver attached—unlike in the 12.9" Pro, this is a nondestructive process. The speaker even has little spring contacts, so it lifts out cleanly.
    • Not so for the ribbon cables that remain glued to the rear case, however.
  9. iPad Pro 10.5" Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The fight with the speaker adhesive on the opposite side rewards us with access to the rear-facing camera and light sensor.
    • The light sensor is covered by a green/white/clear filter that might help with the True Tone system.
    • The 10.5" Pro adopts the same formidable cameras found in the iPhone 7.
    • The rear-facing camera now shoots up to 12 MP stills and 4K video at 30 fps, all with the benefit of optical image stabilization. This is up from the 8 MP stills and 1080p video capable cameras found in the 2015 12.9" Pro.
    • The front-facing selfie camera is no slouch either, as it can take 7 MP photos and has 1080p video recording.
  10. iPad Pro 10.5" Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A tablet is only as powerful as its processors. Here's what's powering this one:
    • Apple APL1071 Apple A10X Fusion chip with 64-bit architecture and embedded M10 coprocessor
    • Micron MT53B256M64D2PX-062 1600 MHz 2 GB LPDDR4 (2 chips for 4 GB of RAM)
    • Toshiba THGBX669D4LLDXG 64 GB NAND flash memory
    • NXP 67V04 (PN67V) NFC controller (as seen in the iPad 5, iPhone 7, and Apple Watch Series 2)
    • Murata/Apple 339S00249 wireless module
    • 2 x Broadcom BCM15900B0 touchscreen controller
    • Apple 343S00118-A0, 343S00120-A0, and 343S00121-A1 power management
    Hello,
    Do you know where can I buy 343S00121-A1? My IPAD pro 2017 restarting time to time
    Pasan Madusanka - crwdns2934203:0crwdne2934203:0
    I believe the flash memory part number is “THGBX6G9D4LLDXG” (with a G in the middle instead of a 6), not “…X669D…”. “G9” fits into the Toshiba NAND flash part number as meaning “512 (=2⁹) Gbits =64GB”, whereas “69” isn’t listed in any of the part number decode specs I found (all the characters for those spots are a letter followed by a number, not two numbers). Also, looking at the full-res (7042x5282) photo here, the character looks a bit closer to the “G” earlier in the part number, and less like the “6” right next to it.
    Slipp Douglas Thompson - crwdns2934203:0crwdne2934203:0
  11. iPad Pro 10.5" Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • IC Identification, continued:
    • Cirrus Logic CS42L83A audio codec and likely CS48L10A0 voice/audio digital signal processor
    • Texas Instruments LM5662A0 backlight LED driver
    • Diodes Incorporated PI3USB102E 480 Mbps USB 2.0 switch
    • Analog Devices ADAU7002 Stereo audio converter
    • Invensense accelerometer
    • Bosch Sensortec pressure sensor
    • NXP Semiconductor CBTL610A38, likely a display port multiplexer
    NXP Semiconductor CBTL610A38 thats a tristar
    Eigirdas Gedgaudas - crwdns2934203:0crwdne2934203:0
  12. iPad Pro 10.5" Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Teardown Update—A closer look at the logic board reveals something interesting:
    • Cypress CYPD2104 USB Type-C Port Controller
    • What’s a USB-C controller doing in here? The iPad doesn’t have a USB-C port.
    • Ah, but if you pair this little chip with a Lightning-to-USB-C cable and Apple’s 29W USB-C charger, you unlock a bonus feature: USB Power Delivery, a.k.a. fast charging.
    • Previously featured only on the 12.9” iPad Pro, fast charging cuts your battery charging time in half. (This was an especially big deal on the 12.9” model, which otherwise needs up to five hours to drink enough electrons for a full charge.)
    Do you know if fast charging would work with a 87w TouchBar MacBook Pro charger?
    Joshua Karns - crwdns2934203:0crwdne2934203:0
    Do these Type-C controllers present in the smaller iPad Pro 9.7 (before this time), 'cause I am buying a referbrished iPad Pro 9.7
    Xavier Jiang - crwdns2934203:0crwdne2934203:0
  13. iPad Pro 10.5" Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Because of the pull-tab adhesive securing its battery, we deemed the original iPad Pro the first really recyclable iPad. Hoping for lightning to strike twice, we apprehensively peel up some tape on the edge of the battery.
    • Foiled! More plastic spacers, and only nasty gooey adhesive instead of nice clean peel-out stickums.
    • How about next time Apple? Cherry on top?
    • This Pro gets a 3.77 V, 8134 mAh, 30.8 Wh battery—a slight downsize from the 38.8 Wh battery found in the 12.9", but an upgrade from the 27.91 Wh battery in the 9.7".
  14. iPad Pro 10.5" Teardown: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Oh, and one more thing.
    • The last time we tore down one of Apple's smart keyboards, it didn't go so well. This time though, things are different—we've got superpowers. (Okay, we've got friends with superpowers.)
    • The Smart Connector is that dark bar at the top of the stand roll. Also featured in black: the various magnets that keep this guy in position.
    • Hopefully the single switch on that spacebar doesn't make it a pain to use, but look at that lovely tracery. Sigh.
  15. iPad Pro 10.5" Teardown: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Pro 10.5" Teardown: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • That's all folks!
    • Special thanks to Creative Electron for lending us their X-ray goggles!
  16. crwdns2935195:0crwdne2935195:0
    • While not soldered in place, the battery is very solidly adhered—no more pull tabs like we saw in the iPad Pro 12.9".
    • The Smart Connector port is virtually impossible to replace—but incorporates no moving parts and is unlikely to fail.
    • The LCD and front panel glass are fused together. This slightly simplifies the opening procedure.
    • The fused front panel increases the cost of screen repair, and the risk of damaging the LCD when opening.
    • Gobs of adhesive hold everything in place, making all repairs more difficult.
    crwdns2935097:0crwdne2935097:0
    2
    crwdns2935197:02crwdne2935197:0
    crwdns2935199:0crwdne2935199:0
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
212,894 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
crwdns2947412:042crwdne2947412:0
Hey Guys! I would love to know what's the RAM memory of the new iPad Pro 12.9... When can we see a teardown of that iPad? cheers!
hansdesigns - crwdns2934203:0crwdne2934203:0
Both 10.5" and 12.9" iPad Pro use Apple A10X processor, the system memory 12.9" uses should be same as 10.5", LPDDR4.
JJ Wu - crwdns2934203:0crwdne2934203:0
I was waiting for iFixit.com to teardown the iPad Pro 10.5 but the LTE version because it could let us know what's Apple's plan with next iphone modem. This new iPad is supposed to support CDMA Network so I want to know if it is using an INTEL modem or a Qualcomm modem. If this iPad uses an Intel modem with CDMA it means intel is ready to substitute Qualcomm on Verizon/Sprint iPhone. The specs in Apple website shows this new iPad Pro supports up to 450 Mbps so it could be using Intel XMM 7480 modem. It also could be using Qualcomm Snapdragon X12 LTE Modem (600 Mbps) and Apple slowed the speed down to 450 Mbps just to have equal specs for both iPads (GSM and CDMA).
Piogan Dominicano - crwdns2934203:0crwdne2934203:0
From the tech spec of new iPad Pro Apple released on product web site, most likely, it is still Qualcomm modem inside due to CDMA support. Unlike iPhone 7, there are several models which is base band tech dependent. For new iPad Pro, there is one model only to support all telecommunication tech, especially CDMA. Intel's first chip to support CDMA will be XMM7650 announced in Feb.
JJ Wu -
Will you teardown the new 12.9 model?
imjosejab - crwdns2934203:0crwdne2934203:0
Is the Touch ID the same as on the iPhone 7, a tactile one or still the (not so) good old clickable one ? Thanks !
Stephane Grienenberger - crwdns2934203:0crwdne2934203:0
It's the older mechanical clicky button version. ;)
Jeff Suovanen -
What is the NFC chip doing inside a iPad?
RaySajuuk - crwdns2934203:0crwdne2934203:0
It's for Apple Pay.
Paul Motz -
NFC is useful for pairing bluetooth speakers, for example. Probably more so than for paying for stuff using a massive ipad..
Patrik Floding -
Right now with the NFC Chip and IOS11 you can skip the whole installation/activation process buy touching the iPad with your iPhone, and it is going to setup all your settings and accounts ;-)
djlsb - crwdns2934203:0crwdne2934203:0
Hello, I just received my iPad Pro 10,5. I have a stylus with 3 magnets in it, and it attaches perfectly to the sides of the iPad. My question is: Is it dangerous or is prepared to that?
Adrián Iriarte - crwdns2934203:0crwdne2934203:0
The iPad relies on magnets to secure the Apple made covers, and has a line of magnets on the case you can see in a few steps. So don't worry, it's supposed to do that =)
Sam Goldheart -
who is the manifacturer of microphones, ambient light sensor, accelerometer, barometer, and 3-axis gyro? cheers
Marco Leo - crwdns2934203:0crwdne2934203:0
Could you precisely measure the size of the new A10X chip? It would be fantastic to get a indication of the die size!
Ewout - crwdns2934203:0crwdne2934203:0
I just finished checking them out at Best Buy. Both the new 12.9" and the 10.5". I have to say WOW. The 12.9" is just to big for my needs, but I got to try the pencil on it for the first time and have to say, WOW is it responsive. Having used them on Windows type systems over the years and being laggy and really not very good, I can't see any lag. It's so responsive. I can't draw worth a crap, but I could see some uses for having it, just on the 10.5" version instead. Right now I have a iPad 3 and it's really laggy. It wasn't super fast either then NEW which is why Apple released the iPad 4 6 months later with a faster CPU and the lightning port. So I think this new 10.5" iPad will be the perfect upgrade. I don't need a keyboard.
It's a really nice Tablet. For the few things it might not do as well, I still have my Custom Windows 10 Pro Desktop at home. For tablet needs. I don't want a so called full OS. Don't want to deal with all the Windows issues I've have to deal with over the years.
JBDragon - crwdns2934203:0crwdne2934203:0
What's the audio codec in iPad Pro 10.5?
cuiimws - crwdns2934203:0crwdne2934203:0
seems, it is Cirrus Logic CS42L83A. Refer to Step 11, there is one chip next to Toshiba chip.
JJ Wu -
I received an iPad Pro 10.5" LTE and Bluetooth is dead. WLAN and everything else works. Never had this before. You can switch BT off and on but the device can't be found nor does it find anything. Restored it twice with 10.3.3 and nothing works. How can this be? I thought the WLAN/BT is on one chip? Lost connection to the antenna? Very strange...
Erik
plant agoo - crwdns2934203:0crwdne2934203:0
can anyone tell me who manufactured those speakers?
jon aarin - crwdns2934203:0crwdne2934203:0
Any clue as to the wiring/schematic behind the smart connector? Which contacts might be the pos/neg used in charging for the Logitech base?
Kyle Hatton - crwdns2934203:0crwdne2934203:0
Ok, I recently deiscovered a small bulge on the back of my iPad directly above the charging port. Also, the metal frame right underneath the home button somehow got dented inwards. I was wonder what might have gotten pushed up, as I didn’t see it here in the tear down. Thanks!
iDeas Guy - crwdns2934203:0crwdne2934203:0
Hi everybody!
I trying to find if is possible to buy original part - lcd assembly for ipad pro 10.5 (a1701). Or if the parts from china are the same like original part (which manufacturer is best?). Eventualy which diferences are between the apple factory display and china spare parts? I am afraid of bad quality of china spare parts.
Thank you very much for reply - I am hopeless…
adm_ferrum - crwdns2934203:0crwdne2934203:0
hey there adm_ferrum,
I’m on the same boat as you. Did you ever buy a chinese LCD?
Paul -
Hi there, is it possible to replace the power button on the ipad pro 10.5” model?
tony.john1 - crwdns2934203:0crwdne2934203:0
Hi , From where can i get the original back case of the i pad ? Please i need help
Leen Baattiyah - crwdns2934203:0crwdne2934203:0
Where can I find a screen replacement for the iPad Pro 10.5? Is there any plan to demonstrate replacing the digitizer from the LCD display?
Michael Gomez - crwdns2934203:0crwdne2934203:0
Unfortunately, replacing a digitizer that’s bonded to the display like this is not really a DIY—it requires expensive equipment (far more than the value of the device) and a lot of time and practice. For most owners and repair shops, it’s much more practical to replace the entire display assembly. Not sure when that part will be available though.
Jeff Suovanen -
Does anyone findout a white spot on the lcd nearly 4-5cm above the home screen? I always take care my iPad Pro 10.5, suddenly after 13 month of usage, the white spot appeared. Many iPad Pro 10.5 users have this issue. Apple won’t replace the screen if it already out of warranty, but I believe that this problem is not caused by user, but the design of the iPad Pro 10.5 itself… Let me know if you also have the same issue with yours. Thanks.
Ivan Putera Pratama - crwdns2934203:0crwdne2934203:0
@ivanputeraa Just a guess, but this sounds like what happens when something is pressing against the back of the screen from inside the device.
Jeff Suovanen -
It´s also known problem with this model, what I understood, it is usually only cosmetic problem. But the white spot might get brighter after some time.
Further reading: https://forums.macrumors.com/threads/bri...
Kristian Hukka -
I have the same issue. Started recently, that’s why I’m curious what that white rectangle component is above the home component on the Logitech board. If something was pushing, there would be an obvious bulge, I’m guessing. It would be nice to solve this mystery seeing as so many people have had the same issue.
Leah Beth -
I’ve had a diagnostic done on an iPad Pro 10.5 (2017) model which won’t power on - it did power on a couple of times then went off after 1-2 minutes but won’t come on at all now. The result of this diagnostic says the company is that it’s not repairable as the issue related to CPU. My question is does this sound like it’s the end of the road for this iPad? Is it worth a second opinion? Can a CPU be replaced?
Terry Newman - crwdns2934203:0crwdne2934203:0
Does anyone know what the white rectangle component is right above the home component on the Logitech board.? I’ve been searching but it’s all mapped out except that one. Would love to know, thank you
Leah Beth - crwdns2934203:0crwdne2934203:0
My mom’s ipad has a different storage module. It’s sandisk.
Jc Soriano - crwdns2934203:0crwdne2934203:0
My version of this iPad stopped being able to charge. I got a new one because repairing it would take too much time (and I wanted the 2018 model).
I gave it to someone else who took it to a store to get repaired.
I had described the issue as being an issue with the lightning port. I said I thought that was the issue because if I wiggled the plug when it was connected, I could sometimes get it to connect and start charging. It would stop when I let go of the pressure I put on the plug.
But now the store has said that that did not fix it. I assume they mean they replaced the port.
So I’m just wondering, what else COULD be the problem? Given the description of how it was behaving.
(Hope that made sense. English is not my native language)
Eirik Havre - crwdns2934203:0crwdne2934203:0
What would need to be repaired if this was submersed in water. The repair places says just buy a new one but can it be repaired?
Jeremiah Bowles - crwdns2934203:0crwdne2934203:0
Okay, as much trouble as this is, and the fact that I don’t have $2,000 to spend on a new 2020 iPad Pro, what would I need to replace my bent back plate? I have the back plate, but it’s apparent that many of the items are still glued into the back plate in this tear down. Speaker cables, screw mounts , etc.
I noticed it was bent, I guess from being stuffed into my messenger bag, as I noticed light leaking slightly out of the top. I’ve had some issues with the screen going darker and the LED lights on the edge by the home button become visible sometimes. I had planned to buy a battery pack. Mine will no longer hold a charge for very long. I’m essentially tethered to a power bank most of the time. Now, I am guessing I will need a battery pack to fix the batteries, a new LCD screen digitizer and the screen retention set that glues everything goes back together. I’m also assuming I’d need to purchase new speaker cables, etc that are glued in. Looking more like a pro job now. Bend is by the 3 dot keyboard link.
Instead of a complete teardown, I’ve considered buying a new LCD digitizer and a battery pack. While I have these items removed , try to bend the back plate back into position as close as flat as possible. I never use the keyboard connection and the device works fine when the Digitizer is pushed back into place until the glue comes loose again. All of this glue and the screen is loose? The screen has a few blue streaks on a couple of apps, and a couple of small bright spots that are permanently there. I know that a 2020 iPad Pro is in my future. Also waiting to see if Apple is going to push for a new device every year! It’s BS as we buy our devices outright! I expect about 4yrs out of them & No contract! If they start making devices that don’t upgrade for more than a year or two, I’m done with Apple!
If I replace the battery pack and the LCD screen, the issues should not be issues with the device working properly until I get another device. Anyone think this is a better option than a complete teardown?
crwdns2936751:024crwdne2936751:0 21
crwdns2936753:07crwdne2936753:0 113
crwdns2936753:030crwdne2936753:0 490
crwdns2942667:0crwdne2942667:0 249,959
