Sony Ericsson s710a Teardown
crwdns2936025:06crwdne2936025:0 —
On the non-camera side of the phone, remove the four 3mm screws and two 2.3mm screws holding down the twist-structure.
When you lift this off, you will need to disconnect the cables from the other side using the same method as in Step 5.
Again, be sure to record which port each cable was in, and the orientation in which they were plugged into each socket.
