Polaroid One-Step 600 Teardown
crwdns2936025:021crwdne2936025:0 —
The final tab holds several spring loaded pieces together, these may pop out the moment the tab is released.
The final tab is located below the backside of the photo-counter dial.
The numbers will be right side up if you are looking in the right direction.
Once all four tabs are removed the plate pulls out from the slot in the rear.
