crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Polaroid One-Step 600crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Polaroid One-Step 600 Teardown, Polaroid One-Step 600 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown, Polaroid One-Step 600 Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown, Polaroid One-Step 600 Teardown: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the flash/lens compartment of the Polaroid camera to a 30 degree angle with the horizontal.
  2. Polaroid One-Step 600 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the flash section of the camera from the main body by unhooking the sides.
    • BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
  3. Polaroid One-Step 600 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the battery/ cartridge compartment fully.
  4. Polaroid One-Step 600 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert spudger in between face of camera and sides where the four tabs are located.
  5. Polaroid One-Step 600 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once tabs are released, pull face of camera straight out.
  6. Polaroid One-Step 600 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the capture button if it did not pop out when you removed the face.
    • There are two pieces to the capture button and both should be removed.
  7. Polaroid One-Step 600 Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the back of the camera, you have to find the tabs located near the hinges of the battery and film compartment.
    • Using a screw driver, pry the tabs of the outer case away from the metal frame.
    • Once the tabs are removed slide the metal frame forward.
  8. Polaroid One-Step 600 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery and film compartment latch
    • Pull the metal frame away from the case.
    • The entire case will come off but the flash compartment will come with the insides of the camera.
  9. Polaroid One-Step 600 Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, pop the battery and film cartridge hatch from its hinges.
    • The tabs are located at the bottom of the metal frame.
  10. Polaroid One-Step 600 Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the sight by lifting it straight up.
    • Follow the red wire from the flash compartment
    • Take the red wire off of the 2 hooks
    • Slide the uncovered wire end out of the small brass clip. Move wire away from camera.
  11. Polaroid One-Step 600 Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the black wire from flash bulb to the back of the case.
    • When you find the brass tab, pull it up. When the tab is free, remove the tab from the black wire.
  12. Polaroid One-Step 600 Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the metal band from the flash compartment to the brass tab.
    • Unhook the wire on the left of the brass tab.
    • Remove the metal band from behind the brass clip.
    • Set the now detached flash compartment to the side.
    • Pull the brass tab up and out like the first one and remove the uncovered wire.
  13. Polaroid One-Step 600 Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the brightness adjuster to right and off the camera.
    • Use the pointed end of the spudger to lift a small latch located next to the bottom of lenz plate
    • Then find the small latch located below the plastic bridge that is over the shutter mechanism
    • This latch is small and is hard to see but you just have to push it with the pointed end of the spudger to unlatch it.
  14. Polaroid One-Step 600 Teardown: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the pointed end of the spudger, pull the band wire out of the electric motor.
    • In the same manner as above, remove the band wire from the plastic extension.
  15. Polaroid One-Step 600 Teardown: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the lens plate up to unhook the plat from two tabs located at the top of the plate.
    • Remove the lens plate, flash compartment and wires from the camera.
  16. Polaroid One-Step 600 Teardown: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the uncovered wire around the side of the camera
    • Remove the metal spring tab next to the counter
    • Remove the brass tab by lifting the top piece over the notch and sliding back.
  17. Polaroid One-Step 600 Teardown: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the small brass tab with the uncovered wire running through it.
    • Remove the wire by sliding under the hooks.
    • then unhook the uncovered wire from the the final latch located on the top of the plastic extension.
  18. Polaroid One-Step 600 Teardown: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The cameras insides could now be in two major pieces.
    • The Pyramid and the lens plate
  19. Polaroid One-Step 600 Teardown: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The top of the pyramid has cover that can be lifted off
    • Below is the mirror which is held in by a tab.
    • Lift the tab with the spudger and pop out the mirror.
    • If you intend to reassemble the camera make sure the mirror is completely clean without any spots or fingerprints because they will affect the quality of your pictures.
  20. Polaroid One-Step 600 Teardown: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are 4 tabs total that must be removed for the next step
    • The first is directly under the spring mounted at the back left of the camera
    • The next is located on the front of the plastic extension
    • The third tab is used to connect the metal frame to the outer plastic
  21. Polaroid One-Step 600 Teardown: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The final tab holds several spring loaded pieces together, these may pop out the moment the tab is released.
    • The final tab is located below the backside of the photo-counter dial.
    • The numbers will be right side up if you are looking in the right direction.
    • Once all four tabs are removed the plate pulls out from the slot in the rear.
  22. Polaroid One-Step 600 Teardown: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the large gear away from its pin
    • The next piece is loaded with a small spring.
    • Carefully lift the "Y" shaped plastic piece from its pin and pull the spring from the pin as it is removed.
  23. Polaroid One-Step 600 Teardown: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Spring attached to the photo-counter dial.
    • Lift the photo-counter Dial off of its pin.
  24. Polaroid One-Step 600 Teardown: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the spring attached to the film eject metal slide.
    • Remove the film eject metal slide
  25. Polaroid One-Step 600 Teardown: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic extension by pulling it from the slot in the rear of the camera.
  26. Polaroid One-Step 600 Teardown: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the metal gear from the gear set.
    • Pull the "L" shaped black plastic piece off of its pin.
  27. Polaroid One-Step 600 Teardown: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are four gears to remove.
    • The gear on the left goes first, followed by the the right.
    • The right gear has a small leaf spring between it and the gear below it.
    • Then remove the black gear and then the last white gear.
  28. Polaroid One-Step 600 Teardown: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the pointed end of the spudger, press the clip that is beneath all the gears next to the electric motor gear.
    • Lift the plastic box containing several long metal tabs
    • Then slide the box out.
  29. Polaroid One-Step 600 Teardown: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the electric motor straight out of the plastic piece.
  30. Polaroid One-Step 600 Teardown: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the spring located in the middle of the plastic mechanism.
    • Remove the two loose plastic pieces.
  31. Polaroid One-Step 600 Teardown: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the metal frame, press the two tabs with the spudger and slide it forward.
  32. Polaroid One-Step 600 Teardown: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the point of the spudger, remove the band wire from the solenoid.
    • Remove the small LED from its clip, and then lift the flat wire array and the flash compartment away from the back of the lens plate.
  33. Polaroid One-Step 600 Teardown: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the solenoid from the back of the lens plate by removing the two tabs.
  34. Polaroid One-Step 600 Teardown: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lens by pressing the tab.
    • CAUTION: The lens may pop out when the tab is released.
    • Remove the back of the lens plate by unhooking the three clips that hold it together.
    • CAUTION: The Shutter leaves may fall out during this step.
  35. Polaroid One-Step 600 Teardown: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the spring on the plastic bridge that attaches to the shutter mechanism
    • Remove the Shutter mechanism from the back of the lens plate.
  36. Polaroid One-Step 600 Teardown: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid One-Step 600 Teardown: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the Clear dial by unhooking the tab at the bottom of the dial
    • Lift the light blue piece out of the mechanism.
    • Lift the black piece out of the plastic plate.
  37. Polaroid One-Step 600 Teardown: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the clear green prism from the plastic plate.
  38. Polaroid One-Step 600 Teardown: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The disassembled camera.
Adriano Agostino
crwdns2935283:001/22/10crwdne2935283:0
50 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 16-31, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 16-31, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S16G31
crwdns2947412:011crwdne2947412:0
Is it possible to remove and change the camera straps for this camera?
stylencreate - crwdns2934203:0crwdne2934203:0
Yes, after step 8 you will have the back case free then in the inside you will see the latches of the plastic plate that holds the strap, pry them carefully are 6, 2 on each side and 2 in the middle, in the middle of doing it myself have stopped since was no need for that so cannot tell you more.
eportillo5000 - crwdns2934203:0crwdne2934203:0
Show me how to teardown the flash plz
RAW Fish - crwdns2934203:0crwdne2934203:0
RAW Fish: Get a terminal driver or other thin device, and wedge it where you can see a line between the outer casing and front panel (where it says “Polaroid” with the rainbow logo). This will need a bit of brute force, but you will be able to seperate a right-angle of outer casing, from the back of the flash, and another right angled bit full of electrics and the front panel. DO NOT touch any of this electrical gubbins - discharging the capacitor through your fingers will HURT. From here you can take out the circuit board and do with it what you wish.
Ariane N -
Hi ! Thanks for your article ! I just bought a Barbie polaroid 600 ;) but unfortunately the flat wire between the camera the flash is disconnected (it dangles from the camera). I managed to remove the flash, that is no longer connected. Do you know how can I open the flash part to reconnect the wires ? Thanks ;)
Marie Dodue - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 84
crwdns2936753:030crwdne2936753:0 286
crwdns2942667:0crwdne2942667:0 64,142
