Philips SPA3210 Teardown
crwdns2936025:02crwdne2936025:0 —
Slip more opening picks under the gray plastic shell to separate it from the orange one, starting from the bottom.
Slowly, raise the gray shell equivalently on each side.
If you lift only the same side, you risk breaking the plastic connections that attach the shell to the rest of the speaker.
You can help yourself with the metal spudger to lift the shell if the fixing glue underneath is too hard.
