crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Philips SPA3210crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Philips SPA3210 Teardown, Free the cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips SPA3210 Teardown, Free the cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips SPA3210 Teardown, Free the cable: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pass the satellite speaker's audio cable through the opening in the back so you can proceed more comfortably.
  2. Philips SPA3210 Teardown, Remove satellite speaker's front cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips SPA3210 Teardown, Remove satellite speaker's front cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips SPA3210 Teardown, Remove satellite speaker's front cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slip more opening picks under the gray plastic shell to separate it from the orange one, starting from the bottom.
    • Slowly, raise the gray shell equivalently on each side.
    • If you lift only the same side, you risk breaking the plastic connections that attach the shell to the rest of the speaker.
    • You can help yourself with the metal spudger to lift the shell if the fixing glue underneath is too hard.
  3. Philips SPA3210 Teardown, Open the satellite speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips SPA3210 Teardown, Open the satellite speaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips SPA3210 Teardown, Open the satellite speaker: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew all four screws from the orange shell.
    • Separate the orange shell from the white case.
    • You won't need tools for that.
    • Be careful not to separate the orange shell completely because the audio drivers are still connected.
    • Remember that you may have to remove excess glue with preciption tweezers, in order to unscrew.
  4. Philips SPA3210 Teardown, Open the main speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the volume knob by lifting it with your fingers.
    • Repeat the Step 2 and Step 3.
  5. Philips SPA3210 Teardown, Ta-dan!: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips SPA3210 Teardown, Ta-dan!: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips SPA3210 Teardown, Ta-dan!: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You can unscrew each audio driver for replacement.
    • You can unplug the main speaker's circuit for fixing.
    • You can unscrew (the two main screws) and unglue the power supply for replacement.
    • You can unscrew (the two diagonal screws - position may vary) and open the power supply's cover for fixing.
    • Do not open the power supply if you do not know what you are doing.
Emanuele Artusi
crwdns2935283:010/23/24crwdne2935283:0
776 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 404
