Westinghouse Stick Mixer 800W Teardown
crwdns2936025:05crwdne2936025:0 —
The main plastic body (95g) can now be removed. Ideally, this would be heated up to melt the glue holding in place the accessory attachment point to the frame, however in this case a plaster saw was used along the part lines to separate the shell
Height:183mm
Diameter: 54mm
After the shell is cut, we can access the motor, main PCB, and accessory attachment point. These parts can be pulled apart with some force
