Westinghouse Stick Mixer 800W Teardown
crwdns2936025:02crwdne2936025:0 —
The device uses 2 buttons to attach different accessories to the base shaft section. These buttons (<1g) are press fit in, and with enough force they can be removed
Diameter: 9mm
Upon removing the buttons, the silver trim (<1g) around the base can be slid off
Diameter: 54mm
Height: 16mm
Following this, the metal sleeving (20g) can also be removed. This casing requires some force to take off as the tolerances are very low
Diameter: 54mm
Height: 91mm
